Full Version: How to get CV's out...
Andyrew
All the bolts are out. and the trani side is off... the trailing arm side is not...
Anything im missing??
I took 8 bolts off completely... (4 per side)
Mueller
QUOTE (Mueller @ Feb 14 2005, 03:06 PM)
but don't just slam away, tap it while you turn the wheel until it comes lose ...
cool.gif Andy
Eric_Shea
The pins, sticky grease and the gaskets are holding it in place. I yank the stub axle and bang away on them in the garage.
DJsRepS
Soak it with PB blaster over night and then the BFH (Big FFn Hammer) I used a chisle in the crack to seperate then had to use a file to dress up the chisle marks.
Andyrew
I just said "screw it" and took the end (you know the 300 lb bolt...) bolt off, then separated it off that. It took a while after I did that too!!!
Andrew
type47
there are 2 big pins locating/holding the CV joint
