91422.7
Apr 2 2015, 06:02 PM
WTB: I realize this is pretty petty but I'm missing some pieces that is needed to attach my Accelerator cable to the F.I. body! This is a 1975 2.0L Engine with matching F.I.. I've attached some pics if that helps. If no one has these pieces laying around maybe you could direct me to a supplier! Thanks
TheCabinetmaker
Apr 2 2015, 07:16 PM
I have all the parts, but which ones specifically?
OK, I see you are missing two nuts and washers that mount the cable housing to that bracket it's sitting in.
91422.7
Apr 2 2015, 07:48 PM
QUOTE(The Cabinetmaker @ Apr 2 2015, 06:16 PM)
Thanks for responding, I can come up with the nuts and washers you mentioned I'm sure at the hardware store but I DONT have the hardware to connect the end of the cable to the end bracket! Thanks
TheCabinetmaker
Apr 2 2015, 08:02 PM
The cable end attaches to the barrel clamp. It should have a small bolt that uses an 8mm socket (3mm bolt?) In the end of the barrel.
Apr 2 2015, 08:53 PM
Thanks for the information, do you have those pieces? thanks
boxstr
Apr 2 2015, 09:40 PM
I have the pieces at CAMP 914. I will pull them off the shelf tomorrow, send an email and I van end pic to make sure we have the right stuff.
Craig at CAMP
91422.7
Apr 2 2015, 11:25 PM
QUOTE(boxstr @ Apr 2 2015, 08:40 PM)
Craig at CAMP
.....Sounds great, talk to you tomorrow! r996tt@yahoo.com
boxstr
Apr 3 2015, 02:20 PM
Email sent.
Craig
91422.7
Apr 4 2015, 08:28 AM
Curt and Craig thanks for your assistance! I found the piece I needed locally! Craig you had mentioned you thought you had one, if you have already mailed it, that's fine, I could always use an extra one! Let me know! Happy Easter....Roy
boxstr
Apr 4 2015, 09:09 AM
I'll hang on to this one. It will probably be here when you need another one.
Craig at CAMP
