Harpo
Apr 3 2015, 08:00 AM
If we have already upgraded to 911 adjusters on our rocker arms would this tool work on our 4 cylinders?
http://www.pelicanparts.com/techarticles/P...mpaign=20150402Thanks
David
SLITS
Apr 3 2015, 11:11 AM
It is doubtful that you will be able to fit the tool to the valves near the suspension ears.
Elliot Cannon
Apr 3 2015, 07:57 PM
Probably work great with the engine out. I use a box end wrench and a dime.
infraredcalvin
Apr 4 2015, 12:32 AM
I have this tool, used it on my 930 rebuild (engine out) I found that it seemed to work ok, a third hand would be best. If using feeler gauges it seemed spot on. When I measured with a dial gauge, all measured fat. I ended up setting with the dial gauge on each one. Nice having everything exact...
Harpo
Apr 4 2015, 07:40 AM
Stompki has a similar tool that uses a dial gauge but that is really expensive
David
puffinator
Apr 4 2015, 10:57 AM
QUOTE(Harpo @ Apr 4 2015, 09:40 AM)
David
The Stomski tool is great.
