A couple of tips:
1 - Some, but not all, valve covers have tabs on the inside that keep the gasket from "squirting" out of place (to the inside where you cant see it).
This pics shows them:
If you dont have these, someone can weld some on.
2 - I have used this method many times and you should never need to replace them again:
Using Blue RTV, glue the cork gaskets into the cover side leaving the head side dry, wait an hour and install them on the car with the mating surface CLEAN. Wait for them to dry.
Remove them, and put a
thin coat of the same silicone on the side of the gasket that mates to the head and wait for it it tack up.
Coat the head mating surface on the head with oil and install the cover.
Now next time you remove the cover it should come right off with a very smooth mating surface. If you did this right, the gaskets will last for a very long time.
