QUOTE(Geezer914 @ Apr 5 2015, 06:39 PM)
Correct me if I am wrong, but if you pre-fill the oil filter, the oil pressure would build up faster, which is what you want to happen. If the oil filter is empty, then the oil filter would have to fill up before the oil pressure would start to build up. I always pre-fill my oil filters when changing oil.
The oil pump in these engines pulls oil from the sump and pushes it through the filter to the pressure regulator and then on to the cooler & engine internals.
If you take a system that has never been primed before and fill the filter first, then the pump (which starts out full of air) has to push the oil out of the filter using air before any oil makes it up from the sump to prime the pump.
If you start with an empty filter, the pump will prime quicker because it is pushing air with air, not pushing oil with air.
Now if you have a way of priming the pump before ever cranking the engine, then you are a master.
Never thought about it, but a vacuum bleed hand-pump could prime the pump if you could attach it to the filter bracket and pull the oil up through the pump....
