QUOTE(gothspeed @ Dec 31 2017, 08:47 AM)
Just need to know if clear portion stays on with headlights
Yes they do. They are on the same circuit as the tail lights. They come on with the first click of the light switch (running lights) and stay on with the 2nd click of the light switch (headlights).
I rewired my running lights to come on with the ignition key. This is done very easily at the fuse panel.
Here's what I did.
First located the running light fuses on the fuse panel. These are noted as 58 on the owners manual.
For always on lights, I took switched power from the 15 group of fuses; the 25A fuse. To keep the running light current from the ignition switch, I added a relay to switch the power.
For full time power, (not switched), I grabbed power from the 30 group of fuses; the 25A fuse. The relay will connect the running light current to this fuse.
Click to view attachmentI removed the 2 fuses for the running lights to verify these are the right fuses (they were). With fuses out, I turned on the running lights to determine which side of the fuses the power came in on. That means the other side are the running lights.
Click to view attachmentHere's the relay I used. It's a simple relay available at most FLAPS. The red wire at the top of the picture is the relay coil which is connected to the switched power from the group 15 fuse. The brown wire is the negative of the coil and is attached to a chassis ground point.
The black wire is a relay contact and is connected to the constant power on the group 30 fuse.
The 2 red wires at the bottom are connected together and will attach to the group 58 fuses to the running lights. The original wires from the light switch to the running light fuses are disconnected and taped off.
Click to view attachmentDone.
