Tony C
Jun 4 2003, 09:14 PM
This is off of Rich Bontempi's car. I had the car to inspect the rear control arms and their mounting points for damage and to fix a crack in the left side inner pick-up point. I'd say this is damaged!
Clicky here for pics!-Tony
EdwardBlume
Jun 4 2003, 09:16 PM
Is that thing bent??!!
Jun 4 2003, 09:19 PM
QUOTE(cavwpguy @ Jun 4 2003, 08:16 PM)
it sure looks like it!
i've seen some other parts that came off that car recently that were equally "abused" ...
Andy
Tony C
Jun 4 2003, 09:28 PM
Bent, cracked, and for some reason would not allow the alignment to be set to spec.
Actually the damage was hidden very well as it was consealed under a brake duct, so from a first look at it you would have never noticed.
-Tony
Bleyseng
Jun 4 2003, 09:37 PM
I take it he hit something pretty hard.
Geoff
Tony C
Jun 4 2003, 09:39 PM
No, He didn't hit anything, just 10+ years of winning puts a little abuse on the equipment.
-Tony
Jun 4 2003, 09:41 PM
QUOTE(Bleyseng @ Jun 4 2003, 08:37 PM)
i frequently hear stories about Rich going off track on purpose to pass slower cars that won't let him pass
Jeroen
Jun 5 2003, 03:40 AM
Yikes...!
Well, at least Rich won't have any trouble providing a replacement
Got any pics of the damaged inner pickup?
cheers,
Jeroen
URY914
Jun 5 2003, 08:32 AM
Where is the stiffening kit sheet metal pieces?
He doesn't have the arms boxed?
Paul
brant
Jun 5 2003, 08:46 AM
I know there is a big controversy around whether it is good or bad to use the boxed-stiffening kit.
I'm not trying to stir up trouble and I know brad has said previously that the kit is not a good thing.
But it looks like this arm definitely flexed enough to pull apart. I wonder if the stiffening kit would have helped with that... or.... just hidden the tear?
what do you think Tony?
brant
Tony C
Jun 5 2003, 10:41 AM
Just like Brad, I prefer either no stiffening kit or a different version. If you "box" the control arms and have an "off" the new stronger control arm will damage the pick-up points and those are far more expensive to fix than a control arm. Rember this control arm has probably 10,000+ laps on it.
-Tony
