QUOTE(ThePaintedMan @ Apr 21 2015, 08:50 AM)
QUOTE(Tom @ Apr 21 2015, 06:55 AM)
The first line simply states that relays do not develop a time delay.
But along the lines of a bad connection/ground that eventually "awakens" while driving, you could also suspect that the relay itself is sticking. Eventually going over a bump just right causes it to unstick.
The cure is the same though, clean all connections, sockets, etc first. If the problem still persists, try swapping relays, right Tom?
The thing is, even if I don't hit any bumps, just smooth driving, it will come on eventually. I've even experimented at a stop light. I look at my lights in the reflection of the car in front of me. My fogs will not be on. I'll turn them on and off and maybe they will come on while sitting there. Or a couple of times I've turned my lights off all the way (headlights) then back on with the fogs and they'll come on. It always seems to be a common factor of how long I'm driving the car.
A couple times I'll let it run in the garage. Fog switch is on but no light. Then after a while, turning the switch on and off (or just leaving it on), they will come on just sitting there idling. So there's no bump to make a physical change in the connection. Very odd.
Anyway, if all these black round relays are the same, I'll just swap on known good working one with the fog one to see if that makes a difference. I'll also clean the connections with some 0000 steel wool and alcohol too.
This may be a similar problem....
My right blinker is also acting up (gauge light, not external). If I turn my left blinker on, the light in the gauge works fine. If I turn my right blinker on, the light will blink twice then go off (actual turn signals still blink, I'm just talking about the light in the gauge). Sometimes, it will come on again at random and blink once then go off. But regularly, it will blink twice when I first turn it on then stop blinking.
I think Carol Anne's in my electrical system.
