QUOTE(Vacca Rabite @ Apr 20 2015, 04:57 PM)
Anyone have a CAD or other pattern for the dashboard? I'm going to redo mine this summer and I want to make a wood dash. But I need a pattern.
Zach
If your unable to locate one don't fret. The width is continuous (3.5" IIRC) except at the steering wheel where it needs very slight dip. Hold the piece against the dash and mark the hole locations from the back. Then drill out these areas but much smaller than actual size. Now place it back upon the dash and use a air grinder w/ a rotary file to enlarge the holes to the true size. The metal holes in the dash will serve as a guide for the rotary file. You'll should use 2 different files. I used a 1" and a 1/4" file. Mine is aluminum but wood should file as easily.
