914ltd
Apr 22 2015, 10:25 AM
Hi all
My last batch of new 13" Bosch blades will not work (properly) on 914 and 911-912 wiper arms. They now only have clips for 9mm arms. Any solutions?? Thanks, Brad
Apr 22 2015, 10:40 AM
Weird. I just bought a set from my local Flaps maybe 3 months ago and they had the correct clip.
r_towle
Apr 22 2015, 10:45 AM
just bought a set of bosch and they would not fit....
Seems the metal arm is too wide or something....
hard to see why it wont slide into place, but it wont....
Rich
green914
Apr 22 2015, 01:14 PM
I bought a set of Bosch wiper blades last month had same problem
I took the clips out of the old blades, and used them on the new blades.
Tom_T
Andy may have a set from the older batch that still fits.
Brad - I'd send the whole order back to Bosch or your distributor that they're improperly made & make Bosch aware that they've screwed up this run, as they may not even know, or maybe it was an ill advised change not thinking of all the vintage/classic cars still using old school blades!?
I'll try to remember to ask the Sierra Madre Collection folks sponsoiring at the PCA Z8 SGVR Concours this Sunday if they had the same problem, but PM me on Monday for results, cuz I'll probably forget to get back to you with everything else I've got going on right now. You know .... that "half-zymers" at our age!
Good Luck!
Tom
Larmo63
Apr 22 2015, 01:27 PM
Larmo63
Apr 22 2015, 01:29 PM
914ltd
Apr 22 2015, 08:10 PM
This is the only Bosch arm adapter that even comes close. It is too wide and does not have the crucial lock tab to keep it in place. I have used all my old adapters. Just wish there was a proper part for this.
Good project for 914Rubber.com?
Brad
somd914
Apr 22 2015, 08:24 PM
Two weeks ago I bought a set of Bosch MicroEdge blades - a bit tight to get on but fit. Maybe my wiper arms aren't original.
andys
Apr 22 2015, 08:45 PM
Same experience with the Bosch wipers blades. Returned them for some off-brand which fit fine.....Not to worry, since it doesn't rain is SoCal anyway.
Andys
rgalla9146
Apr 22 2015, 08:47 PM
Off topic a bit.
Long ago I heard that if a car was fitted with SWF blades it had a SWF wiper motor.
Bosch blades ?....Bosch motor.
Also it's been years since I saw any blades that didn't extend onto the windshield trim.
This is an important topic, that those who want to use their car all year can get new blades.
Larmo63
Apr 22 2015, 08:51 PM
There is a bulletin in the technical manual on this subject. It says to mount the left (driver) wiper on a higher angle as for the blade to miss the windshield trim. There are drawings and a measurement called out. The blades on eBay I mentioned above ARE correct, but they are pricey.
GeorgeRud
Apr 23 2015, 12:46 PM
I finally gave up on the Bosch blades as they seem to fall apart too soon. Bought some PIAA silicon blades and they fit fine.
If I have any old Bosch adapters sitting around the garage, I'll send them your way Brad.
r_towle
Apr 23 2015, 01:24 PM
QUOTE(GeorgeRud @ Apr 23 2015, 02:46 PM)
better at clearing the water?
Float at speed?
did you buy them online or in person somewhere?
rich
r_towle
Apr 25 2015, 07:32 AM
somd914
Apr 25 2015, 07:40 AM
My experience with PIAA on my wife's Bimmer has not been good - metal ribs keep popping out of wiper and have also been very noisy.
GeorgeRud
Apr 25 2015, 05:27 PM
I bought the PIAA blades on Amazon, but even though they clip onto the wiper arms fine, the clips are a bit too wide. Unless the SKF wiper blades fit correctly, I can't think of many other options that look right on the car.
914_7T3
Feb 24 2020, 08:06 PM
Resurrecting this thread as my new Bosch wiper blades do not fit the Bosch wiper arms. Can't reuse the old clips as I've mangled them beyond recognition.
Anybody have a solution for what type of blade will work?
Came across this listing for SWF and thinking about picking up a set as it specifically references both 7mm & 9mm wide arms. The Bosch arms are 7mm at the end that clips to the blade.
SWF- Valeo Wiper Blade Assembly
P/N: 96462890102
MY70-76 - 914 Base, 4, 6 Front Left ~ Fits 7 & 9 mm wide wiper arms.
Front Right ~ Fits 7 & 9 mm wide wiper arms.
https://www.autohausaz.com/porsche-auto-par...eplacement.html
914ltd
Feb 25 2020, 10:48 AM
I found these Trico blades. 13" black 7mm arm. The fit perfect and are cheap. I'm not sure how long they last but they are 1/2 the price of the Bosch blades that have 9mm arm fit.
Brad Mayeur
dr914@autoatlanta.com
Feb 25 2020, 11:31 AM
we try to use the original SWF or valeo blades no problem with the fit
eric9144
Feb 25 2020, 12:20 PM
Interesting timing as I just had to do a 3.5hr drive home in my 914 in the rain and the drivers side wiper was terrible.
These Bosch wipers claim to have 7mm hooks, since I need them anyway based on this past weekends drive, I'll order them and let you guys know.
https://smile.amazon.com/Bosch-MicroEdge-40...974+Porsche+914
FlacaProductions
Feb 25 2020, 03:40 PM
Got these from Wiperbladesusa.com - perfect fit.
914_7T3
Feb 25 2020, 05:41 PM
QUOTE(eric9144 @ Feb 25 2020, 10:20 AM)
https://smile.amazon.com/Bosch-MicroEdge-40...974+Porsche+914 @eric9144 Not sure those are going to work as those are the ones I ordered. You can see from the attached pics that the B6 attachment for 7mm is for a straight arm at the tip and not a hook. Regardless, let me know should you achieve success.
Click to view attachmentClick to view attachment
bbrock
Feb 25 2020, 08:01 PM
Mikey914
Feb 25 2020, 08:27 PM
Yes we could make a clip that would work if necessary. Just irritating that the wipre manufacturers are changing spec and we get caught in the middle.
Mark Henry
Feb 26 2020, 06:40 AM
QUOTE(Mikey914 @ Feb 25 2020, 09:27 PM)
@Mikey914 How about making refills, just the squeegee for the old bosch wipers? Back in the day I used to just replace the rubber squeegee part.
Seeing I have two 914's and a beetle I'd buy almost a dozen sets of refills.
Mikey914
Feb 26 2020, 11:11 AM
Yes that is fairly easy. The dies cost a bit and I would be running thousands of ft of material as it's not a large extrusion. The question is the profile. I'll put up a thread and see what we get.
Mark
914_7T3
Feb 26 2020, 02:31 PM
Add these POS blades to the list with Bosch that do not fit as advertised.
914_7T3
Feb 26 2020, 02:36 PM
QUOTE(bbrock @ Feb 25 2020, 06:01 PM)
OK
@bbrock , I'll give these a go instead of eating the shipping to return the SWF blades. Will post up on the fit once I get them.
mxkinn01
Feb 26 2020, 03:21 PM
The last set I bought for my bug was the same. I had to use the old ones. Looks like I’ll be in the same boat when I replace the ones in the 914.
Sorry I’m no help.
Mike.
bbrock
Feb 26 2020, 03:58 PM
QUOTE(914_7T3 @ Feb 26 2020, 01:36 PM)
OK
@bbrock , I'll give these a go instead of eating the shipiing to return the SWF blades. Will post up on the fit once I get them.
Are the SWF blades 9mm also? I was hoping those would work. Look forward to hearing about the adapters. It would be nice to be able to mount modern blade styles even if they don't look period correct.
914_7T3
Feb 26 2020, 04:20 PM
QUOTE(bbrock @ Feb 26 2020, 01:58 PM)
OK
Yup, 9mm for the J Hook and 7mm adapter without the J Hook, same as the Bosch.
eric9144
Feb 26 2020, 05:31 PM
Porsche Classic is now listing wipers:
http://www.classicshop.porsche.com/pcos-us...6462890102.html I'm curious which ones they are. I noticed the parts selection seems to be expanding which is a good thing but man ~$31 per wiper is steep.
914_7T3
Feb 26 2020, 05:53 PM
QUOTE(eric9144 @ Feb 26 2020, 03:31 PM)
Same part #96462890102 as the SWF at $4.91 each. I would bet $31 that the Porsche Classic ones don't fit either.
Mark Henry
Feb 29 2020, 04:49 PM
If you have the new bosch blades I may have figured out a work around. I just wrapped a short length of SS cable the around the wiper arm and it takes up the oversize well.
I'll try to post some pic's later.
Mikey914
Feb 29 2020, 06:13 PM
WOW
Should we really have to modify wiper blades to make them fit???
As the value of the cars go up, it makes our cars look janky!
Seems like if I make an adapter that fits the "modern" wipers it would make more sense
bbrock
Feb 29 2020, 09:24 PM
QUOTE(Mikey914 @ Feb 29 2020, 05:13 PM)
WOW
914_7T3
Feb 29 2020, 11:36 PM
QUOTE(bbrock @ Feb 29 2020, 07:24 PM)
WOW
Still waiting for the adapters to arrive from Amazon. Will post on fitment as soon as they arrive.
Mikey914
Mar 1 2020, 02:04 AM
Yes if there is a solution that looks stock no need to make them.
Mark
eric9144
Mar 1 2020, 10:00 AM
Got my new Bosch MicroEdge wipers from amazon yesterday...and... they
don't fit the arms at all, had to swap the old clips out to make them work.
The clips didn't want to seat on the arms correctly with too much thickness top to bottom, preventing the positive "click" from engaging as well as being just slightly too wide so even if it had clipped in they would have wagged on the arms when in use.
That being said, swapping clips is a no brainer, provided you have clips and they're still in good condition.
Johny Blackstain
Mar 1 2020, 11:21 AM
New Bosch wipers do have some honking plastic, so I did the swap to the old clips
914_7T3
Mar 2 2020, 11:09 PM
QUOTE(914_7T3 @ Feb 26 2020, 12:36 PM)
OK
These are a no go as well.........................
bbrock
Mar 2 2020, 11:23 PM
QUOTE(914_7T3 @ Mar 2 2020, 10:09 PM)
OK
That sucks! Sounds like we need
@Mikey914 to come to the rescue. It's pretty ridiculous these clips aren't available from the blade manufacturers.
914_7T3
Mar 2 2020, 11:32 PM
DRPHIL914
Mar 3 2020, 08:03 AM
QUOTE(914_7T3 @ Mar 3 2020, 12:32 AM)
I have some Bosch blades that are new in box at home from Okteenerfest a few years back I will check to see but I think those look exactly like what I have, will recheck tonight. I can tell you they just don't seem to grab and hold very well,
Phil
bbrock
Mar 3 2020, 09:09 AM
Here are the clips I just took off my 30+ year old Bosch wiper holders. Same as the clips in Johnny Blacktain's pic above. Of course, the one on the left was brittle and shattered
Click to view attachment Click to view attachment
914_7T3
Mar 8 2020, 06:09 PM
FlacaProductions
Mar 8 2020, 06:38 PM
So...what was the final answer?
914_7T3
Mar 8 2020, 08:06 PM
QUOTE(FlacaProductions @ Mar 8 2020, 05:38 PM)
Found them at one of my go to parts sources...Bug City! They have the adapters for the 7mm wiper arms.
Mikey914
Mar 8 2020, 11:34 PM
I'll bring in a few of these so they will be easy to find.
Mark
