Turns out that my wiper motor & parts vanished, so, now I need a replacement, any help would be appreciated. 914-628-019-10-OEM is the part number for the motor, it the rest the same as a 4??
Either way, looks like I need a replacement
TIA
sixnotfour
Apr 25 2015, 09:00 PM
you can make a hybrid linkage..it requires a 4 wiper linkage and a 69-73 911 linkage..it has the correct mount for the motor...But the wiper shafts are too long.. trim the tubes to the 4 length, install 4 linkage and you will have to drill a hole in the center of the stabilizer mount..so it ends up with 3 holes..( 2 which can be welded closed) oddly enough my 6 bracket is painted silver not zinc plated.. so then install the 6 motor and youre done.... OR find a complete unit..Good Luck Sucks losing valuable pieces..JKH
sixnotfour
Apr 25 2015, 09:30 PM
