If you can take the gauge to the kitchen it is easier. I used a 12v battery from my drill and a few wires and aligator clips. Get a wire to hang the sensor in the pan of water so it is only touching water.
If you look closely at the outside edge of the gauge you will see #s to help you. Stick a meat thermo in the water set on *C and compare.
I'll see if I can find my post with pictures.
FOUND ITThat thread is good for testing only. We did not fix anything by adding a POT, ignore that part. I ended up getting new gauge guts, but have not gotten my taco plate etc... coming from across the pond. I'll re-try to fix at my next oil change.
