Can I remove the angle drive and run it with out it leaking fluid?
I should probbly know this but I never wanted to try it.
Thanks,
Paul
QUOTE (dlee1967 @ Feb 17 2005, 06:31 PM) |
In theory you should be able to do so. The seal for the speedo gear shaft is then exposed. If it is in good shape, then there should be no leaks. In most cases it is old and brittle and has been seeping, but the angle drive has been containing (slowing down) the leak. If you find it starts to leak, remove the speedo gear housing (one set bolt) and replace the O ring and the inner speedo shaft seal. I just put together a gearbox for my wifes V8 and another for my track car with Quaife, so this is fresh in my mind. I replaced the seals in this area. David Lee |
