ken914
Feb 17 2005, 09:17 PM
I ADDED A PHOTO OF MY "NEW" CAR. SCROLL DOWN ABOUT 15 POSTS...
After 4 years of searching I just bought a 914-6 with a 3.2 and flares! The car is in route from California to SC, should have it in a few days! I can't wait. My first car (1981) was a 1971 1.7, then a 2.0, have always wanted a -6
The car is going to need tires soon, it has 15x7 and 15x8 rims. The suspension is very stiff and the frame is stiffened (with dog ear stiffeners).
I'll use it for AX, PCA events, running around town, AND JUST HAVING FUN.
I was hoping to get new 285's to replace the 285's on the rear but nobody makes them anymore. What do you guys recommend for tire type and size for this car???
Thanks for your help!!!
xitspd
Feb 17 2005, 09:59 PM
I raced the car attached for three years with 15x7's and 15x8's. I ran 225's all the way around. I do not think you should run larger than 255's on an 8 inch rim.
iiibdsiil
Feb 17 2005, 10:41 PM
On a Chevy, with a 17" rim that is 8.5" wide, the maximum recommended is a 275, although people were running 285's on a regular basis. Not sure if you can get away with the width though because of the rim being a smaller height therefore more sidewall though, so you can curve it in though.
I have 225's on mine, not sure of the rim width, I run like 20 PSI in my tires and have fun with it on the street. I don't take it to the track though.
xitspd
Feb 17 2005, 11:06 PM
Check out www.bridgestone.com and look at the high performance Potenza wheel chart. 225/50R15 tires call for an approved rim width of 6-8 inches.
225/50R15 91W W BW 101-222 6.0-8.0
anthony
Feb 17 2005, 11:35 PM
Pics pics pics!!!
Andyrew
Feb 18 2005, 12:50 AM
How the heck where they fitting 275 on a 8.5 in rim????
We talkin trucks here?? cus it would have to be a large diameter tire.. (275 70 17's or so..)
Cus if I can fit like 265's on my 17's I would like it much betta...
Andrew
iiibdsiil
Feb 18 2005, 01:55 AM
I'm talking 94-96 Impala SS's. They come with a 255 stock.
ArtechnikA
Feb 18 2005, 06:48 AM
Goodyear G-19 slicks.
SLKWrx
Feb 18 2005, 07:02 AM
on the front 7" setup, I wouldn't exceed 235, on the rear, that can go up to 255. I'm forgetting the overall rolling diameter of a 914 wheel/tire combo so I'm not sure of the profiles that you should be going after.
VegasRacer
Feb 18 2005, 07:16 AM
Here is a
size chart that should help with your choices.
I have 225 - 50 - 16's all the way around on 8" wheels on my flared 3.0 / 6.
This set up seems to look and perform well for me.
Congrats on the new car Ken. You're gonna love it.
d914
Feb 18 2005, 07:45 AM
hoosiers for the track offer a 245 that will fit on a 8". I belive outside of slicks thats as big as your going to get. Otherwise you'll need 16"s..
SLKWrx
Feb 18 2005, 09:23 AM
So is 25" the optimal rolling diameter? because if so, your choices are much easier to figure out
Feb 18 2005, 11:46 AM
QUOTE (ken914 @ Feb 17 2005, 07:17 PM) |
I was hoping to get new 285's to replace the 285's on the rear but nobody makes them anymore. What do you guys recommend for tire type and size for this car??? |
285s on 8" rims?
i'd say 225 for the 7" and 245 for the 8". good tires are still readily available in those sizes.
just FYI, the factory ran 285 on 9" rims ...
Andy
maf914
Feb 18 2005, 11:56 AM
I was just checking a Yokohama tire brochure. Their recommended maximum width tire for a 7" rim is 225 and for an 8" rim is 255.
Mueller
Feb 18 2005, 01:50 PM
QUOTE (Andyrew @ Feb 17 2005, 11:50 PM) |
Andrew |
i've got 225's on my 8's (front) and 255's on the 9's (rear), my next set of tires (those nice Falkens everyone is raving about) will be going on as soon as they start to deliver them....265's will be going on the 9's...rims are 17" dia.
1973914
Feb 18 2005, 02:03 PM
For what you are doing, 225/50/15 on the front and 225/45/15 on the rear.
ken914
Feb 18 2005, 08:16 PM
Here is a photo of my car.
Thanks for all the help.
VegasRacer
Feb 18 2005, 08:48 PM
Have you considered stepping up to 16" or 17" wheels? If you have real Fuchs on there now you can probably sell them for enough to get some bigger ones. The 15 x 7's are in high demand.
anthony
Feb 18 2005, 10:54 PM
16x8 and 16x9 Fuchs are also in high demand.
Andyrew
Feb 19 2005, 12:56 AM
So... Does this mean I can run 265/40/17's on a 8.5 in rim??
Or even a 275/40/17??
I could fill out the bontempi flares better with more tire...
iiibdsiil
Feb 19 2005, 01:47 AM
I don't know that you will get it with that sidewall, but most likely, yes. The sidewall might be too short, although a 255/50 and a 275/40 are probably pretty close, ey?
anthony
Feb 19 2005, 07:31 PM
Here are what I assume are NLA 285-40-15 Pirelli P7s:
http://www.craigslist.org/eby/car/60311876.html
Feb 19 2005, 07:55 PM
yupp, those are the ones ...
BUT
they haven't been made in 15 years or more. those tires are OLD. they're probably hard as a rock.
i wouldn't touch them with a
if your life means anything to you, don't run tires that have been sitting for 15+ years ...
Andy
