nickg
Feb 17 2005, 09:32 PM
i have a set of neew looking webers from my 914-6. my question is are they all safety wired? it says on the side idt, are the rebuild kits the same as an ida?(ther is a set on ebay that's why i ask)
bwilless
Feb 17 2005, 09:48 PM
I think that the only difference between IDA's and IDT's is some smog type things. I think you can actually modify the IDT's to basically become IDA's. Experts please correct me if I'm wrong.
ArtechnikA
Feb 18 2005, 06:14 AM
IIRC the only parts wired on a /6 Weber are the venturii retaining grub screws.
what do you see that is wired ?
nickg
Feb 18 2005, 09:47 AM
i will take a picture and post it tonight
bob
Feb 18 2005, 10:32 AM
I think Rich is right the only thing wired is the venturi retaining screws.
The Throttle Stops are different as well as the mixture screws. you can use either throttle piece on either carb, but you have to use the correct mixture screws. (there is a 'step' on the IDT, while the IDA is tapered)
