QUOTE(era vulgaris @ Apr 30 2015, 07:20 PM)
It's been here in the classifieds for a few weeks already
http://www.914world.com/bbs2/index.php?showtopic=253446It
appears to be rust-minimal. Pics of door gaps while jacked up are nice. I think in this market $6-7K with the issues it has is fair, if the body is as solid as it appears. $3K seems a little harsh. My '72 sold honestly for $5K, and we all know how bad that car was...
My two cents. The CL ad states the cons are:
Cons:
Crummy paint job.
Transmission: No 1st gear synchro, 1st to 2nd needs a little finesse when cold.
Odometer not working, stuck at 42202.
Emergency brake not connected.
Heater hoses not installed.
Windshield trim included but not installed.
Seems to have been hit center-rear at some point, panel was replaced. Can't tell from outside, but trunk floor is a little sloppy.
Rear valance not installed. (2 included)
Think it could use control arm bushings.
Wiper scratches on windshield.
For $8700 I would expect the simple "Cons" to be addressed. Fix the EBrake cables, put the valances on it, install the heater hoses. At that point it is $5-6K car at best.
The trans work if you can't do it yourself will be $1500 and paint, if you wanted painted and done right is in the $6k range. Windshield trim I bet isn't stalled because the clips are broken. In order to replace them you need to pull the windshield. The big issue for me is the damage repair. Is the car straight?
There are much better cars for $8700. If you are just looking for a driver then fine Maybe $5k. It is a 72 1.7, oil bath engine. No sway bars, no center console, on steel rims. A hard sell at that price when you can find full optioned 2.0L cars similar condition in the $6-$7K range.
