dangerranger01
May 1 2015, 07:39 PM
My driver's seat belt in my '73 locks up every few inches as I pull it out
. Then I have to pull it out another few inches before locking up again. Now repeat
. Needless to say, it takes about 2minutes to buckle up when I go out for a drive. Passenger's side is fine.
Anyone experience this problem and know of a fix (or have a good belt one for sale?
)? It is kind of a pain in the butt everytime I go out with it...
Thanks!
ripper911
May 1 2015, 07:49 PM
I've heard that if you get it all of the way out and use scotchbrite on the webbing it will help.
I still need to do that.
Dave_Darling
May 1 2015, 08:12 PM
Pull it all the way out and use a binder clip or two to keep it extended. Clean it with mild soap and water, rinse. let dry. It should work better, though maybe not perfect. Scotchguard can evidently help, too.
--DD
GeorgeRud
May 1 2015, 08:50 PM
A re webbing service would be a great addition. As these belts are at least 39 years old now, having new, flexible webbing would be nice. Cleaning and lubricating the mechanism would also help!
steuspeed
May 1 2015, 09:24 PM
IIRC taking apart the mechanism is not recommended. Very difficult to put back together.
Cuda911
May 1 2015, 09:42 PM
I had the exact same problem. I pulled the belt all the way out to it's farthest extension, then sprayed the roller mechanism with silicone lube using one of those thin straw-like spray extenders. Works like new!!!
bdstone914
May 2 2015, 07:05 AM
You can remove the thin side cover to clean and inspect the internal parts. Dont try to take off the side cover with the spring.
You can buy the webbing online. I used to take them to an upulustry shop that would resew the end parts. Just not DOT certified.
SKL1
May 2 2015, 07:08 AM
I had seatbeltplanet redo the belts in my '73. Look and work like new and reasonable price.
GeorgeRud
May 2 2015, 07:18 AM
Thanks for the link, I'll give seatbelt planet a look. I'd love to get some new webbing installed on my retractor belts.
JmuRiz
May 2 2015, 09:14 AM
Good info, I'm sure most of our belts need refurbished.
somd914
May 2 2015, 01:56 PM
Mine did the same and opted for the SeatPlanet fix. The ones I bought fit the factory receiver so still look stock.
dangerranger01
May 2 2015, 02:42 PM
Maaaad thanks guys. I'll try cleaning them and also lubing up the rollers...hopefully it helps out.
Porsche930dude
May 2 2015, 05:48 PM
I found that changing the orientation of how it mounts helps. loosten the bolt and try it in different positions and make sure the belt is pulling straight out.
Mblizzard
May 2 2015, 08:31 PM
After cleaning the belts spray with Scotch Guard. Keeps them sliding.
dangerranger01
May 3 2015, 12:19 AM
Is this the scotchguard y'all are talking about?
http://www.walmart.com/ip/Scotchgard-Fabri...-10-oz/13281231Do I spray that on both sides of the belt after cleaning??
My webbing seems soft and good/usable so hopefully I can get away without a rebuilt unit.
Mblizzard
May 3 2015, 05:44 AM
QUOTE(dangerranger01 @ May 2 2015, 10:19 PM)
That's it.
