djporsche
May 3 2015, 01:54 AM
G e o r g e
May 3 2015, 02:10 AM
Nice looking car
sixnotfour
May 3 2015, 02:12 AM
Looks Clean...I love the 70's esp. the green ones..
914Sixer
May 3 2015, 06:41 AM
It is a real early car, may have some different items on it.
arkitect
May 3 2015, 06:50 AM
Nice looking green. L041 is black, I'm partial to green but black is cool.
Custom made center console w/ speaker?
Dave
Maltese Falcon
May 3 2015, 09:40 AM
Clean and straight 914, the 2056 w/carbs looks like a proper hot rod T4
Marty
Cairo94507
May 3 2015, 10:13 AM
Nice looking car - Irish Green is what it looks like to me.
djporsche
May 3 2015, 11:57 AM
Thanks guys. yes it's Irish green but the og color was black. Black was a option so probably not a lot of them around.
What different parts came on the early one?
Yeah that's a speaker box center console.
stugray
May 3 2015, 12:42 PM
Nice!
May we ask what you paid for it?
Surprised I didnt notice it being in Boulder, OR that you didnt ask anyone on this forum to look at it for you.
JawjaPorsche
May 3 2015, 12:55 PM
Nice Score!
djporsche
May 3 2015, 01:45 PM
QUOTE(stugray @ May 3 2015, 10:42 AM)
Nice!
I paid 3k and found a guy on uship to ship it for $614 from CO to TX. I think i got a really good deal.
Ian Stott
May 3 2015, 02:09 PM
That is a very good deal!
Ian Stott
Moncton
Canada
Wonderbread
May 3 2015, 03:45 PM
Very clean car from the photos , but not to rain on your parade I believe he told me that the underside is full of rot? I know it's been on & off line for quite sometime, again it looks sharp to me.
djporsche
May 3 2015, 04:23 PM
pan,rocker and hell hole are all solid but the jack point is gone has about 5" by 4" hole. Looks worst in the pics then it is. metal around the hole is solid.
Wonderbread
May 3 2015, 07:34 PM
Good deal, thought hard about it a while back. Guess I should have pulled the trigger. Nice car, and good deal.
914Sixer
May 3 2015, 07:37 PM
Texas Teener, I just realized you are in San Antonio. I am up in Boerne. Give me a call some time. 210-262-4226. We have a few teener's here.
djporsche
May 3 2015, 08:28 PM
Cool yeah i'm in San Antonio. Would be awesome to hook up with other teeners.
rangrbob
May 3 2015, 09:54 PM
I went and looked at your car a couple weeks ago. It would have been mine if it had all the early parts I was in need of.
Take your time and enjoy fixing it up. Don't get discouraged. Half the fun is getting back on the road. After seeing the paint code my plan for it was to strip it down, fix all the metal, and go back to black.
Keep the pictures coming!
Heeltoe914
May 3 2015, 10:42 PM
Easy rust repair very nice car enjoy. LOVE THE GREEN
SA-914
May 4 2015, 06:27 AM
Welcome!
djporsche
May 5 2015, 01:20 PM
The BMW 320i calipers are leaking pretty bad so I bought some early 914 calipers from the classifieds, the red ones I'm sure y'all have seen them. Hoping to have them here soon.
It has 195 65 15 that rub in the rear. The rims are 5 1/2. Is it because it's a early 70? I don't remember rubbing in my other 914's which were all later models. I have a good set of 165's i might through on. My plan is to autocross it but i want to get the structural repairs done first. Then i'll hunt for a nice set of tires.
914Sixer
May 5 2015, 02:36 PM
Rear control arm maybe out of alignment or bushings may have collapsed in it. Also early cars (up-72) have full internal lips on wheel wells . 73-on has the upper part of lip removed.
djporsche
May 5 2015, 03:01 PM
I'll check the bushings. Thanks
rnellums
May 5 2015, 07:35 PM
I drove that car and tuned the carbs on it about a year ago! LOTS of power in the mid-range!
It was a pretty good looking car then too! Congrats!
I'd dive deeper into that rust though. It looked pretty terminal when I was crawling around under it.
djporsche
May 5 2015, 07:59 PM
were the tires rubbing then?
rnellums
May 5 2015, 08:19 PM
Not that I recall, I only took it for a short spin though to prove out the carbs.
Dave_Darling
May 6 2015, 09:19 AM
QUOTE(djporsche @ May 5 2015, 02:01 PM)
That's unusual--generally the tires will rub on the outer fender, not the inner one! I would say that the wheels are too far in, but I thought your pics showed real 914 wheels and those don't seem to have this problem?
I would double-check the bushings and try to make sure the trailing arms are straight. Also make sure you don't have a ludicrous amount of negative camber.
--DD
stugray
May 6 2015, 09:37 AM
QUOTE(Dave_Darling @ May 6 2015, 09:19 AM)
--DD
My car has 205/50 R15s and stock 2L Fuchs and the rears rub on the inside.
I added 3/8" Spacers to avoid that.
And it is set to max camber (no shims).
djporsche
May 6 2015, 10:13 AM
I jacked it up and with a big screw driver i can move the rear arm about 1/4" I'm sure it moves more with all the weight of the car when it's sitting on the ground. I'm ordering new bushings all around.
djporsche
May 6 2015, 04:33 PM
This some kind of new sleeve i don't know about?
rangrbob
May 6 2015, 06:41 PM
QUOTE(djporsche @ May 6 2015, 04:33 PM)
It should be there. It's normally pressed into the bearing. I thought the same thing too.
djporsche
May 6 2015, 07:39 PM
can i still install the sleeve to help get rid of the wobble?
rangrbob
May 6 2015, 09:28 PM
QUOTE(djporsche @ May 6 2015, 07:39 PM)
I'm not really sure were that goes. As far as I know the bushing is pressed into the bearing. There should only be a spacer and a lock ring between the bushing and the bearing.
914Sixer
May 6 2015, 09:57 PM
Sleeve is not for your car. Early cars have unique parts. Very early steering columns shared parts with VW Type 3. Pull the PET down from Porsche and look at the parts diagram.
djporsche
May 6 2015, 11:03 PM
That would explain a lot. I'm missing the lock ring and spacer. Whats the best way to get rid of the wobble? Replace bearing? god i hope not.
djporsche
May 7 2015, 12:47 AM
i looked at the PET and It doesn't show this long spacer i have. It also doesn't show the sleeve for the spring. Just a spring that im missing. is the missing spring my issue? or should i try this.
Jonathan Livesay
May 7 2015, 10:49 AM
Seeing as that is on the passenger side (unless the picture is flipped) I am inclined to wonder about rust damage to the swingarm mounting points being the reason for the wheel moving around. Have you looked at that? Do both rear tires rub in the same way?
Edit: That's the drivers side isn't it? So less likely to be rusted, but still.....
djporsche
May 7 2015, 12:49 PM
driver side. Pass side is ok, no rubbing. the door even shuts nice.
rangrbob
May 7 2015, 01:31 PM
QUOTE(djporsche @ May 7 2015, 12:47 AM)
Nope. You need to find the spacer and lock ring. # 21 & 22 in the picture.
I have a 71 column I could sell you if interested.
Click to view attachmentClick to view attachmentClick to view attachment
francar
May 7 2015, 02:41 PM
enjoy yours 914
djporsche
May 7 2015, 03:01 PM
QUOTE(rangrbob @ May 7 2015, 11:31 AM)
Click to view attachmentClick to view attachmentClick to view attachmenti have 21, i need 22 and 23.
rangrbob
May 7 2015, 03:35 PM
QUOTE(djporsche @ May 7 2015, 03:01 PM)
Yup. Eyes are getting bad.
djporsche
May 7 2015, 03:41 PM
I don't need a column but I'll take the ring and spacer if you have them.
djporsche
May 8 2015, 06:37 PM
The tire were low on air, 20psi. So i put 40psi and now it has 1/2" clearance.
djporsche
Jun 24 2015, 07:22 PM
found the missing parts i needed for the steering column and now the wobble is pretty much gone. The temp gauge is not working so i need to check the sending unit. and the gauge. Also it has an oil leak from the rear main, i think. I made a video, check it out.
https://youtu.be/MORro8InLkY
'73Porsche914Tang
Oct 6 2021, 09:31 AM
QUOTE(djporsche @ Jun 24 2015, 07:22 PM)
https://youtu.be/MORro8InLkYIt's been a while, but any information on where this car went after you sold it? I would love to track it down. This was my first 914 and I regretted selling it immediately.
Any help locating it would be appreciated.
rhodyguy
Oct 6 2021, 09:38 AM
That's a lot of air pressure in cold tires.
mark04usa
Oct 6 2021, 07:28 PM
That's a very early car. What is the VIN? My Jan 70 car is 2791.
