Just to clarify, the "full open to the oil cooler" position for the flaps is the default mode when the thermostat is disconnected and the passenger side flap will be DOWN and flat over the cooler.
It may look like it's blocking the cooler but in that position it actually forces the most air through the cooler.
If you remove or change the position of the flaps the cooler won't get full air.
