As stated in title, Fuse #9 blows within seconds of turning ignition switch to the ON position. Strange thing is, it has been somewhat intermittent. Fuse blew a couple weeks ago. Replaced it and drove for a week and then it blew again. Replaced it and it lasted about maybe a day. Now, every time the key is turned to ON the fuse blows.
Here are some things I have tried in hopes of isolating the source of the problem:
Removed POS lead from battery to starter - blows
Removed yellow wire from ignition to starter - blows
BTW... reverse light wires are disconnected and taped off.
Removed all brake/tail/backup bulbs - blows
Checked for a short between Fuse 8&9 on the fuse panel - no short
Could it be the ignition switch?
The car still starts and runs fine except the following items do not work:
fuel gauge
tach
turn signals
brake lights
alt & oil pressure lights do not come on (when fuse is blown)
Wipers and fresh air fan work.
And, in case it matters... '74 2.0 D-jet
Thanks!
