Keith Black pistons and cylinders and H-beam connecting rods from my 2270cc stroker. These parts were run for 10,600 miles over a period of 18 months before the engine suffered a cam failure . Since I really liked the 2270, my mechanic was able to convince me to pony up for a full new L&N setup during the teardown/rebuild.
So here are the extra parts (minus the original GA heads which I am holding onto for the moment). Everything has been cleaned and mic'd since removal, and all is in good order. There is no damage to anything, including the cooling fins. The pistons were balanced and the rods clearanced and balanced end-to-end during the original build. Rings are not included, and you should swap out the rod bearings before use due to the cam failure.
$300 shipped CONUS. PayPal is good.
