sdoolin
May 6 2015, 01:47 PM
So my speedo quit working a couple of days ago. I have verified that it is not the head unit or the cable itself. Running the tranny end of the cable with an electric drill causes the needle to move.
Looks like it is the "angle drive" unit (to me) that has failed. I have removed this from the tranny and cleaned it up. Spinning the female end of it (that bolts into the nose piece) with a screwdriver only _sometimes_ causes the male end (output to the cable) to turn. It seems very "loose".
I have seen several threads on this (larmo63 has a recent thread) but I cannot tell if the piece is rebuildable and if so, how to do so? Looks like Pelican has replacements but they are $95 and I am too busy spending money on my 911 to go and buy the part from Pelican.
I did search and found great info on how to remove tach to get to speedo to remove speedo cable and trip reset cable, just can't quite find an answer to this specific question.
All help appreciated...
Millerwelds
May 6 2015, 01:59 PM
I bought a used one from BDStone on here. swapped it out and it works fine now. I think I paid $50. Post a WTB and I am sure others will pipe in.
May 6 2015, 02:06 PM
McMark sells a upgraded version that has two o-rings, send him a PM ...
Java2570
May 6 2015, 02:11 PM
914 Rubber is now selling the ones McMark came up with! I got in on a GB for that one....
sdoolin
May 6 2015, 02:43 PM
This is the piece I am referring to. I don't see this available at 914 Rubber (I may be missing it)...
Click to view attachment The side of it that bolts into the tranny seems very loose from the side that accepts the cable. Wondering if it is rebuildable.
Bob L.
May 6 2015, 02:55 PM
Yeah, that's the "Speedo angle drive". Bdstone should be able to help you out.
Send him a P.M.
sdoolin
May 6 2015, 03:04 PM
PM does not find a user named "bdstone"?
Larmo63
May 6 2015, 03:39 PM
I never did get mine fixed. I didn't understand what I should do to fix mine. I never got it the part out of the transmission.
I just guess my speed.
stugray
May 6 2015, 04:45 PM
QUOTE(sdoolin @ May 6 2015, 03:04 PM)
http://www.914world.com/bbs2/index.php?showuser=1319'bdstone914'
bdstone914
May 6 2015, 05:17 PM
Yes i have them. Yes,you should only need the angle drive. The improved upper parts is to fix leaks. Won't make your speedo work
sdoolin
May 6 2015, 05:56 PM
PM sent bdstone914.
This place is great...
Mikey914
May 6 2015, 10:58 PM
Yes the upper is nice to stop leaks. After you get one from Bruce you can sacrifice the old one to see. I have one on my car that someone had removed the end cap and epoxied back together. So, I do believe it can be done. What it takes and how to are still a mystery.
