QUOTE(type47 @ May 8 2015, 02:24 PM)
you could use the VDO dual sender VDO 360 009 on the grease gun hose (or VDO-150-752 if you can find it) and use the correct range VDO oil pressure gauge mounted where you want it (why wouldn't you want it where you could see it while driving?). I found lots of stuff just by searching for VDO, JEGS, try Pelicanparts, GPRparts. Someone on this site mounted a mechanical gauge on the engine, don't recall the username of the poster but I recall that when you said you want it in the engine bay.
More:
http://www.914world.com/bbs2/index.php?showtopic=246121more on hose:
http://www.autoatlanta.com/Porsche-VDO150752-srch.htmlWhy not installing the oil gauge inside cockpit?
1. I think more job to do it and a little bit more money.
2. I just want to make sure I have a good oil pressure by checking it once in a while since I don't really drive this car regularly.
But if the expense is not much and not more job to do it? Maybe it is better inside where you can see it. Like removing the clock along the center console and put the oil gauge.
Thank you again!
