I wanted to engineer a drain into the lines that run from the engine to the oil tank and what I came up with was a T fitting in the line between the oil cooler and the tank.
Originally the T was going to screw directly to the cooler, but it would dump directly on to the headers. Here's what I came up with. First, I couldn't find a 2-3" straight so I
used another T, (this one faces up), then comes a 45 degree and finely the T. This moves the drain off to the side. My mock up is half done in aluminum and half in steel
(cause that's what I could find locally). Damn, the steel is a lot heavier. I'm trying to find the straight and 45 in the blue aluminum so they match. JEGs has the 45, but
so far no straights. My other option would be a 45 with one side longer than the other, but finding that one looks like a reach. Anybody out there have a better idea?
