MikeM
May 13 2015, 07:50 PM
Hello...does anyone know the offset of the 4 spoke 914 Fuchs ?
Thanks.
mskala
May 13 2015, 08:21 PM
QUOTE(MikeM @ May 13 2015, 09:50 PM)
Thanks.
The PET lists all the 5.5" wheels at ET40.
MikeM
May 13 2015, 08:30 PM
ok thanks!!!
MikeM
May 14 2015, 07:46 AM
Now I'm confused. I'm looking at some replicas but the ad says "4 inch backspacing".
What does ET40 mean? 40 mm.?
Mike
rhodyguy
May 14 2015, 07:56 AM
The back spacing, measured with a tape and rule, is 4 5/8" on OEM Fuchs wheels. The 5/8 makes all the dif in the world on a narrow body car, with unaltered wheel wells, and running 195 width tires.
Mueller
May 14 2015, 07:58 AM
QUOTE(MikeM @ May 14 2015, 06:46 AM)
Mike
http://www.tirerack.com/wheels/tech/techpage.jsp?techid=101Offest is an European term, backspacing is redneck (I mean American term)
Backspacing is from the hub surface to the out most point of the rim. You measure this by using a straightedge across the wheel and measure... a picture will explain better than me..
Mueller
May 14 2015, 08:01 AM
If you notice, backspacing takes into account the thickness of the lip, offset does not.
So 2 rims with the same width and offset may have different backspacing depending on how the rims have been made. I wouldn't think it would vary by more than 1/4" to 3/8" max
MikeM
May 14 2015, 08:08 AM
OK great info!! So I guess now I need to ask what is the "backspacing" measurement on a 4 paddle Fuchs wheel?
Thanks
MikeM
May 14 2015, 08:10 AM
OK...I just re-read Rhodyguy's response. So a 4 inch backspace will not work? Correct? It's a narrow body car.
Mike
Mueller
May 14 2015, 08:20 AM
QUOTE(MikeM @ May 14 2015, 07:10 AM)
Mike
I guess you could see what you currently have and compare the numbers?
The rims you listed with a 4" backspace will be closer to the fender edges and
might rub in the back.
rhodyguy
May 14 2015, 08:28 AM
4"? Results may vary. IMHO, a major factor is what size tire you intend to run. You don't want to drop $$ on a wheel and tire package only to find you need to make adjustments to the chassis. Those adjustments, rolling the wheel wells or trimming the lips, will be expensive to undo.
MikeM
May 14 2015, 08:38 AM
Good point. I have almost new 195/55's now so that's what I would be using.
Don't really want to roll the quarter panels.
rhodyguy
May 14 2015, 08:46 AM
What style of wheels are currently on your car?
MikeM
May 14 2015, 08:50 AM
Mahles...should have mentioned that!!
stugray
May 14 2015, 09:52 AM
I run 205 50/15 Hoosiers on the stock 2.0L Fuchs and they rubbed in the rear, on the inside, on the track (probably would NOT rub on the street).
That is with NO shims for camber (max camber).
So I used 3/8" spacers and still have room on the fender side.
195s should fit with the stock rims and no spacers.
Note: LONGER bolts/studs are required (even longer than the special 2.0L-Fuchs bolts) with the spacers.
