Think I may need anew battery, have a red top optima that is around ten years old, I heard a rumour the new ones were not as good. Any suggestions on a good battery for our teeners appreciated.
Ian Stott Moncton Canada
trojanhorsepower
May 14 2015, 02:18 PM
I have worked with the yellow tops and am not impressed.
JmuRiz
May 14 2015, 02:28 PM
As long as it's not parked outside, I would think a 'normal' battery will work well enough.
Ian Stott
May 14 2015, 02:36 PM
What is the proper size to ask for at a battery shop? I don't think they will have a listing for a 914.
My car is garage-kept and keep a battery mat under it.
And someone got three good batteries. I will never use a conventional battery again. I've seen too many victims.
Really the charging method works. My Red top is 12 yrs old. It was down to 4 volts last year once and I charged it. It's been working since.
Chris Pincetich
May 14 2015, 04:22 PM
My Red Top lasted 10 years and I maybe could have resurrected it, but bought a new one after replacing the alternator and wanting to be DONE with any charging/electrical issues for the 914 I rely on to get to work some days. Also, my inexpensive trickle charger was not working to re-charge it.
You need Group 34 YES, most auto parts stores, or their websites, can find the correct size for our cars using their standard databases
somd914
May 14 2015, 04:25 PM
QUOTE(rick 918-S @ May 14 2015, 06:07 PM)
QUOTE(somd914 @ May 14 2015, 03:47 PM)
3 Red Tops in 4 years - certainly took advantage of their 3 year warranty.
I use a CTEK 7002 charger as in the video. I've tried everything. Local FLAPS counter guys say they see countless Optima Red Tops coming back and don't recommend them. And yes, my alternator and voltage regulator check good.
The longest I had one last was 1.5 years, shortest was 9 months. Do a quick Google search and you will find countless threads with similar experiences. Old ones seem to last forever, newer ones seem to be very hit or miss based on forum responses.
I will admit that my NAPA battery will be replaced this year with an Odyssey PC925, but I needed something ASAP to get me on the road rather than ordering a battery and waiting several days.
Robert21
May 14 2015, 08:00 PM
My last red top lasted 10 yrs got a new one been 2 half yrs . no garage carport
maf914
May 15 2015, 08:25 AM
QUOTE(somd914 @ May 14 2015, 02:25 PM)
I am curious about your selection of the PC925 model. When I went to the Odyssey site the battery selector indicated a PC1200MJT for a 2.0 914. Am I missing something? Thanks.
The PC925 seems to be the Odyssey battery of choice in the 914 and 911 worlds for street drivers. Odyssey's website appears to recommend batteries of the same or similar group number, while the PC925 is significantly smaller and lighter. For me, I just need a cranking battery so the PC925 will do just fine - no high wattage stereo running with the engine off. I prefer the smaller size and less weight, 16 lbs lighter than my redtop.
Also, just to clarify things more with my RedTops, they would take a charge; after a drive or putting them on the charger they would should in the 12.4-12.8 V range but would discharge quickly, especially in the cold of winter. My last one got to the point that within 12-18 hours it would discharge enough that I couldn't crank the engine (30-35 deg garage), and thats with the battery switch turned off to eliminate parasitic drain.
maf914
May 15 2015, 01:48 PM
Somd914,
Thank you for the response. I need a new battery and have been vacillating between a standard lead acid type and a specialized type. Thanks.
Shredhead
Aug 18 2015, 09:47 AM
QUOTE(somd914 @ May 15 2015, 03:04 PM)
So from everything I've read, the PC925 is the way to go. Any tips on mounting it in the stock battery tray? I may move it at some point, but would like to put it there for now. Also, why are the CCAs so low on that battery? What am I missing?
Shredhead
Aug 18 2015, 09:57 AM
QUOTE(Shredhead @ Aug 18 2015, 11:47 AM)
Shredhead
Aug 18 2015, 10:04 AM
Sorry for the multiple posts. I edited my first one to add something, but the edit didn't appear and instead it repeated the post? Anyhow, what I wanted to add was that Amazon seems to have lots of variations on the PC925. Which is the best one for the 914?
Briby37
Aug 18 2015, 12:31 PM
Pretty sure this is the one you want (check the SKU):
Going to be doing this same thing in the near future, so curious to hear about your experience with the battery and tray setup.
Thanks Briby, Rennline has a great description of the variations of the 925 here. I'm thinking MJT.http://www.rennline.com/Battery-Odyssey-925/productinfo/EL-PC925/
