tach
May 15 2015, 09:09 PM
1974 1.8 L-Jet. Pertronix 1847V. No spark when cranking over the engine. I do get one spark on a plug when I turn the key switch off and the rotor is in the correct position to spark that particular plug. What to check?
New cap and rotor.
Bosch blue coil.
Update. It looks like the pertonix sensor is to high on the distributor mounting plate.
TheCabinetmaker
May 16 2015, 04:58 AM
Your missing something in your distributor. Points and condenser.
budk
May 16 2015, 05:11 AM
QUOTE(The Cabinetmaker @ May 16 2015, 06:58 AM)
You missed the part about having a Pertronix.
TheCabinetmaker
May 16 2015, 06:05 AM
Well, no. I did not, but you missed my attempt at humor! His pertronics is probably toast. He needs to install points and see if it runs.
Old Yella
May 16 2015, 01:04 PM
rotor maybe---or timing is just out
rhodyguy
May 16 2015, 01:29 PM
Does your timing light flash when you test each plug wire while cranking?
sportlicherFahrer
May 16 2015, 03:08 PM
Had the same issue a couple years ago. Every time it sporadically sparked it sounded like I was shooting ducks in my garage. Neighbors LOVED it!
Failing module from what I could tell. Ended up putting the good ol' mechanical stuff back in and drove down the road fine after 5 minutes of reinstalling and setting timing.
pilothyer
May 16 2015, 03:15 PM
I have found one of the most important things you need when converting from mechanical points to a Pertronics............A SPARE PERTRONICS SET-UP.
timothy_nd28
May 16 2015, 06:57 PM
QUOTE(pilothyer @ May 16 2015, 01:15 PM)
turk22
May 16 2015, 08:01 PM
Make sure the petronix magnet is seated correctly on the rotor. I had a similar problem shortly after original install, it was that the magnet was not fully seated correctly on the rotor.
76-914
May 17 2015, 08:21 AM
They have a trouble shooting guide on their website if you want to check the unit. I've had one set in for 5+ years w/o any problems.
