Hello - I recently bought a 1973 with a 2.0 litter. I am new to the 914. I have a leak/drip coming right down from the oil pressure relieve valve area. It's not coming from the oil filter. I removed the large screw using the biggest screw driver I had. I got a nice new metal gasket with rubber around it. I welded a nut to the screw so install it much easier as well as tighten it much more than I could with the screw driver.
Ran the motor and it still drips down from that area just like it did before. As far as I can tell, its from the screw still but access and viewing from underneath isn't the greatest.
Is there something else around there higher up that may be the issue? Perhaps something with the oil cooler that is close by? Any pointers appreciated.
