thieuster
May 20 2015, 04:12 AM
I went to the workshop for an update on the engine. Alan had been working on it while I was away. And this is how it looks:
Remember the old?
This was this morning:
I'm sure that you can see the difference. And this made me really happy!
Menno
Edit: on the last pic, at the bottom, there's clearly a set of 'lines or ribs' casted in the tin, like a WiFi logo on its side. What's the function of these lines?
Cuda911
May 20 2015, 04:44 AM
Wowza!!! Looks great!
914Sixer
May 20 2015, 05:33 AM
Looking GOOD !!!!!
bdstone914
May 20 2015, 06:27 AM
I think you are referring to the coil mount area on the fan housing. Much better location as it will not crack the tin as will happen when the coil is on the top tin. Requires reshaping of the end of the coil bracket
islabob
May 20 2015, 06:43 AM
Great work.
Cairo94507
May 20 2015, 06:48 AM
I would be extremely happy to walk in and see that ready for the car.
Larmo63
May 20 2015, 06:49 AM
Like this: a better location for the coil, a bit more out of the way
Kansas 914
May 20 2015, 07:22 AM
QUOTE(Larmo63 @ May 20 2015, 06:49 AM)
DRPHIL914
May 20 2015, 07:34 AM
Holy transformation, batman!! awesome!! that is some 914 engine p*rn!
my complements to the builder for sure!
cwpeden
May 20 2015, 07:35 AM
Ditto on the coil mount. Not sure what the wifi logo is for.
jeffdon
May 20 2015, 08:04 AM
QUOTE(cwpeden @ May 20 2015, 06:35 AM)
What ARE those semi circular castings? Always wondered.
Shadowfax
May 20 2015, 08:05 AM
Looking good!
Eric_Shea
May 20 2015, 08:10 AM
Those semi circles help radiate negative ions away from the coil where they are sucked up in the fan and dispersed over the cooling fins and cylinder heads. This allows for better cooling as the negative ions attract cooler air...
76-914
Sharp!
thieuster
May 20 2015, 10:09 AM
QUOTE(Eric_Shea @ May 20 2015, 04:10 PM)
Why didn't I think of that myself! Thanks!
Menno
DavidSweden
May 20 2015, 10:12 AM
QUOTE(thieuster @ May 20 2015, 08:09 AM)
Menno
The disadvantage of locating the coil on the fan housing is that its a bummer to remove when the engine is in the car. The engine looks great!
sean_v8_914
May 20 2015, 10:13 AM
genius man, its also a wave guide to aide in the flow of the expanding and collapsing magnetic field of the coil. like a phase amplifier
colingreene
May 20 2015, 10:15 AM
not really.
Maltese Falcon
May 20 2015, 10:30 AM
Eye candy Menno
From your Topic Headline...I was worried that there would be a small animal DOA in the fan housing !
Take your engine builder out for
Marty
thieuster
May 20 2015, 11:56 AM
When working on the engine, I became aware of something I would never have found with the engine 'in situ'"
The squar-ish thing in the middle where the 4 air intake tubes connect, had a little hole the size of a match head on the underside! So... that will draw in extra air, making the mixture lean!
I didn't notice it before I sent it off to the powder coater. it was so dirty that the hole was invisible. After blasting, the coater called and told me. He welded the hole for me and did a good job with the black powder coating.
Menno
PanelBilly
May 20 2015, 01:29 PM
Wow. That's what an engine should look like. Take lots of photos from every angles and create a thread we could use when asking about a part.
EdwardBlume
May 20 2015, 01:37 PM
Congrats! Leave the engine lid off for awhile!
somd914
May 20 2015, 03:10 PM
New engine looks great, but where's the old? All I saw was a photo of a pile of dirt then a few photos a nice engine...
rangrbob
May 20 2015, 08:58 PM
Sweet!
davesprinkle
May 20 2015, 09:10 PM
Did you powder coat the fan housing? If so, you're likely to have charging system problems. The alternator's ground path is through the fan housing. Be sure you have good metal-to-metal contact at all points from the alternator housing to the engine case. Scrape off the powder coating where necessary.
