ok, so during the limited time I got to drive my 914 (72 1.8L) last summer I got concerned regarding how hot my motor was running (pushed 240-250F a couple of times on very hot days: 90-100F). So my intention this winter was to make sure that I had done everything possible to make the car run cooler.
My goal is to positively conclude whether I need an external oil cooler or not.
here is what I have done so far:
1. verify proper calibration of oil temp guage
2. installed all necessary engine tin seals
3. installed late model air deflectors on the bottom on the car
4. plugged all unused heat exchanger openings (pax side only)
5. verified fan is not missing any blades
6. internal flaps thermostat is missing but flaps are in the full open position.
7. rain tray is still installed
So far, operating temps haven't exceed 220F(once), but air temps have only been in the 80's so far.
My question now is, should I start using synthetic oil? Will Synth oil make the car run cooler or just withstand heat better (i.e. not thin out)?
recommendations are welcome and thanks!!
