rfinegan
May 26 2015, 03:51 AM
While preparing for a motor swap I discover a little hell hole starting its way into my 75/ 914 this week end. I knew the battery tray was getting thin and a few small holes starting. I may as well address this while I have the engine out...
rfinegan
May 26 2015, 03:54 AM
2.0l with weber 44, cam, Kerry hunter 4 to 1, Malory, HI fire...Just a little set back
cary
May 26 2015, 07:35 AM
Not too bad. Take a look at the suspension ear for degradation. If it looks Ok, I'd use one of Mad Dogs patch panels.
Engine look great .................
stugray
May 26 2015, 08:01 AM
Probe that hell hole with a screwdriver and dont be too gentle.
Engine looks clean! However not 2.0L heads so to make sure you are aware.
And I would put a mech oil pressure gauge on that port where you have the VDO sender when you first fire it up to verify that you have pressure.
malcolm2
May 26 2015, 10:28 AM
People always find stuff in pictures, aren't they great?
2nd note on the OP sender.
It needs to be grounded, not isolated like you have it with the rubber or vinyl strap. I used an "L" shaped bracket bolted to the fan housing and a decent hose clamp wrapped around the body of the sender.
Might need a longer braided hose and mount it just to the drivers side of the timing hole.... see the fan housing bolt right there?
rfinegan
May 26 2015, 10:40 AM
Great tips, Thank you. I do have a set of Mad Dog HellHole kit and a set of heater block offs on the way...
rfinegan
May 29 2015, 05:36 PM
The tip on the grounded dual sender, I tested the ground trough the braided line and I do not have an issues, seems to be Good.
Dropped the engine tonight and got a closer inspection of the Little Hell hole, It is not to bad but will need the channel that holds the engines seal. Anyone have a good source for that? Its useable but rusted away in a few places.
I will blast the area a post a few pics before I start cutting
-Robert
cary
May 30 2015, 04:44 AM
Restoration Design sells just the channel in a 3ft section.
rfinegan
May 31 2015, 03:43 PM
today removed the battery tray and saved the support. Bad news the sound pad rusted a hole in the Fire wall so i have to pull the back pad from the interior
francar
May 31 2015, 05:59 PM
rfinegan
Jun 1 2015, 05:02 AM
Here is the battery tray removed
jacksun
Jun 1 2015, 05:11 AM
maybe you could just patch the hole in "the channel that holds the engines seal"
of course, new is best....
I used a wire wheel type attachment on a grinder and a shop vac to remove the
material on the back of the sound pad. didn't want to throw it away, just
remove the material that holds the water.
randal
rfinegan
Jun 1 2015, 08:08 AM
My thinking too Jackson, I have my blaster set up and will start the clean up and rust removal next. The back side of the engine tray has rust and is thin where the fuel pump plug passes through ( if I had a pump there mine is a 75) So i may patch there too. But it looks like removing the tray( or part of the tray) will make the other jobs easier to get too
Claus Graf
Jun 1 2015, 11:20 AM
Nice engine! Good luck with the rust repair! Once I began grinding and cutting I found more rust........
rfinegan
Jun 7 2015, 04:46 PM
Here is a good pic of the inside fender well and how it fits with the frame once the old rusted parts have been peeled back. One more blast of the inner farm and I will cut the inner panel and start replacing. This will be the trickiest of all the parts panels to replace.
-Robert
rfinegan
Jun 7 2015, 04:52 PM
OH, this latest one cost me 4 stitches and a tetanus shoot and a short tip to the ER. Lot of sharp edges to hurt you if you are not very careful
-Robert
rfinegan
Jun 7 2015, 04:58 PM
Here is a pic of the rust under the fire wall sound pad it was a little worst then first expected. I had to remove the interior to get to this one correctly but after the seam sealer and the patch it will last another 40 years
-Robert
rfinegan
Jun 7 2015, 04:59 PM
other side
rfinegan
Jun 7 2015, 05:00 PM
patch
rfinegan
Jun 12 2015, 04:28 AM
Here is the latest fabricated 16g piece almost ready for installation
jkb944t
Jun 12 2015, 05:05 AM
QUOTE(stugray @ May 26 2015, 06:01 AM)
How did you spot that it didn't have 2.0 heads?
Jeff B
rfinegan
Jun 12 2015, 07:00 AM
2.0l heads only have 3 bolts to hold the intakes on and other have 4 bolts...Mine have 4 bolts but bigger valves ;-) Also the plug locations are different on the tins and heads for the 2.0l heads
-Robert
QUOTE(jkb944t @ Jun 12 2015, 03:05 AM)
Jeff B
rfinegan
Jun 15 2015, 05:32 AM
100+ degrees and still was able to get another hole fixed
rfinegan
rfinegan
Jun 15 2015, 05:33 AM
here the patch from the inside
rfinegan
Jun 15 2015, 05:37 AM
Here is the Flux wire welds ,a little dirty but I am sure this is stronger then new not that it is tied to the long stiffeners installer earlier .
A little grinding, primer and seam sealer I think she will be ready for the engine tray, battery tray and the Jwest trunk hinge
Then Paint!
rfinegan
Jun 28 2015, 04:53 AM
Here is a pic of the engine shelf replacement panel or 1/2 panel, ready for installation. The other part was solid and only the u channel for the seal needs to be replaced
rfinegan
Jun 28 2015, 04:57 AM
test/trial fit
rfinegan
Jun 28 2015, 05:00 AM
nice fit
rfinegan
Jun 28 2015, 05:07 AM
another
rfinegan
Jun 28 2015, 05:09 AM
next will be a jest hinge mount, the U channel for the seal and battery tray and LOTS of seam sealer
rfinegan
Jun 28 2015, 03:15 PM
seam sealer and primer added to the U channel
trojanhorsepower
Jun 28 2015, 05:30 PM
Nice work!
cary
Jun 29 2015, 05:54 AM
Looks Great .................
rfinegan
Jun 30 2015, 04:26 AM
Thanks for the encouragement and feedback. Been a great DIY project. I got a second coat of primer sealer on last night and will paint under the battery tray next. Then weld in the tray and seam seal and paint the right side of the engine tray and compartment. With a little luck and encouragement, I think I can get the engine installed over the holiday weekend. This little hell hole set back was a little over 30 days to fix. But glad its almost done and I did not wait...
rfinegan
Jul 3 2015, 05:31 PM
...paint is dry and rubber seals are in place and fuel lines
rfinegan
Jul 4 2015, 04:49 PM
Woot! just need to hook things up and get her running...
Bob L.
Jul 5 2015, 10:56 AM
Nicely done!
I'm so jealous
rfinegan
Jul 13 2015, 05:54 AM
I am going to call this part of the repair done!
Here is a .mov of the first drive in 2 months with the new engine installed mov
https://www.dropbox.com/s/nd6jgowlz6ko4cu/IMG_2218.MOV?dl=0https://www.dropbox.com/s/eslws7ka70lsgcy/IMG_2219.MOV?dl=0
