QUOTE(effutuo101 @ May 26 2015, 11:09 PM)
From the pictures, the through body away is still installed. It looks like you just need drop links.
Man, nothing is simple! I hadn't even entertained the thought of messing with the sway bar other than replacing the bushings on that also. I wasn't aware that the car had the through body style.
Where do I get the drop links and associated hardware? If I use the through body sway bar, do I have to reinforce the sheet metal so I don't tear it if I do some autocross?
Guess I am learning more about the front suspension than I thought I would.
