Allan
Feb 21 2005, 06:50 PM
I was rummaging through my harness to get them cleaned and found this. It's on the same bundle that goes to the coil and relay board. Little bullet shaped push in connectors and one of them is missing. Not sure where it connects either.
pic 1
Allan
Feb 21 2005, 06:51 PM
pic 2
watsonrx13
Feb 21 2005, 06:53 PM
Back-up light switch in tranny....
TheCabinetmaker
Feb 21 2005, 06:56 PM
Yep.
Allan
Feb 21 2005, 07:01 PM
Ah Ha! I figured it had to feed back to that area. Are these type of connectors still around?
Joe Ricard
Feb 21 2005, 07:37 PM
Way to go Rob. So ya must learning something after all. Couple more time to Mississippi and you should know it all too.
brownaar
Feb 22 2005, 09:17 AM
Headrage,
Bullet connectors are readily available. I think the standard size will fit. Try Radio Shack.
Aaron
Allan
Feb 22 2005, 09:47 AM
QUOTE (brownaar @ Feb 22 2005, 07:17 AM) |
Headrage, Bullet connectors are readily available. I think the standard size will fit. Try Radio Shack.
Aaron |
Thanks. I'll give them a visit.
JeffBowlsby
Feb 22 2005, 08:23 PM
Standard bullets are too small, you want the 0.18" size.
Allan
Feb 22 2005, 10:22 PM
QUOTE (bowlsby @ Feb 22 2005, 06:23 PM) |
Standard bullets are too small, you want the 0.18" size. |
And I will find them at Radio Shack? I really hope so because I've been searching all over for a simple thing like a 1/4" pipe thread to 1/2"barbed fitting to vent my heads........................
brownaar
Feb 23 2005, 11:26 AM
Yea......., what Bowlsby said. He is the harness guru. Sorry for the misinformation.
Aaron
bd1308
Feb 23 2005, 12:19 PM
hey...i have one of those in my engine bay area...it's connected to a green wire, but its not connected to anything. Where does this go? it's over by the battery
brownaar
Feb 25 2005, 09:25 AM
bd1308,
If that green wire comes off the main harness under the battery, it sounds like the wire that goes into the center tunnel to hook up the oil temp gauge for center-console cars.
