I put 911 brakes with M calipers on not long ago, but the brakes have never been what I know they should be. I have a strange pulling issue which seems intermittent and is much worse when wet.
I've tried new rotors and pads and made sure the system is bled.
I was going over everything this weekend and found the step in the piston on one caliper does not match the orientation of the other. I'm surprised I haven't seen this before. I have the factory manual so I can figure out what they are supposed to look like.
Before I go and take the caliper off and then push out the pistons I figured I'd ask if anyone has an easier way to spin the pistons.
Thanks for your help,
Kelly
