Hey hey,
So my project is not a huge world away from actually running - however - I have a lot of work to do before I have all the turbo plumbing and control work completed.
I am thinking of getting the thing running by just sticking an airfilter on the throttle body instead of anything more introcate.
So - that would mean I have two turbos - plumbed on the exhaust side, but not on the compressor side.... which is not ideal....
I wondered if one of the following options would be useful:
1) put some wire through the turbine and physically hold the wastegates open.
2) plumb the compressor output directly to the wastegate with a quarter inch air outlet.
3) this is a stupid idea - finish it before you drive it.
What do you guys think? It doesn't feel like a great idea, but taking the turbos off and plugging all the lines is probably more work than getting a minimum setup running anyways.
Also - where would you go for a good selection of pipes, bends and seals for turbo plumbing?
TIA,
Fiid.
