QUOTE(malcolm2 @ Jun 5 2015, 04:17 PM)
QUOTE(LCOX @ Jun 5 2015, 05:46 PM)
Does anyone know if I can use a later 2 port fuel injection fuel pump used on later 1975-76 injection systems on the earlier 1973 2.0 injection system that originally used the earlier 3 port fuel pump? Thanx L
Must be D Jet. I am gonna say NO. L Jet had 2 ports and maybe different pressure. Sorry a vague answer is as good as no answer. But d jet has 3 for a reason.
1975-76 2.0 cars are d-jet.
AFAIK they interchange. The third hose is, to my sort of knowledge, a way of cooling the pump. This was circumvented in later years in the manufacture of internal lines within the pump for the last two model year. Actually, last model year, since my 76 was made in 1975 and was a left over.
Move to CIS and the pressure goes up, so those pumps will not work. In truth anything that will deliver the 28 psi and proper volume that you can hook up and fit should do the trick. I wish there were a JEGS or Summit for Porsche!
