Full Version: subaru install update
scotty914
okay to get it started i need to do the following:
find the mas and plug it in 1 min
make and hook up a starter cable 30 mins
hook up the fuel lines ( 2 12 inch pieces ) 5 mins
hook up the pwr to the brain 5 mins
hook up 2 grounds 2 mins
to get it on the road
install radiator and hoses ( 2 bolts ) 20 mins
fill tranny ( swepco waiting ) 20 mins
install reverse switch and hook up 10 mins
install angle drive and hook up speedo cable 10 mins
hook up clutch 15 mins
throttle cable maybe 1 hour
modify shift bar and install 2 hours
bolt up cv joints 10 mins
loop heater water lines and replace one undernieth 20 mins
install exaust and put a muffler on it ?
finish welding the body motor mounts ?
make a speed sensor for suby brain 2 hours
914helo
scotty914
i just want to get it started before i begin the second part. i think with as much time i have been spending on the car its a week away from being driven, not fully on the road but being driven
Series9
QUOTE (scott thacher @ Feb 22 2005, 11:07 PM)
I'm a week away from being on the road. Let's race (mechanically). We both need time on the road prior to WCC. wink.gif
scotty914
QUOTE (914RS @ Feb 22 2005, 10:30 PM)
Series9
QUOTE (scott thacher @ Feb 22 2005, 11:34 PM)
What do you mean 'if'?
scotty914
QUOTE (914RS @ Feb 22 2005, 10:37 PM)
i givin herr all i caan caaptian
mrihop
Every time I draw out a schedule, I forget to unplug the phone and all my buddies decide to stop by! beerchug.gif
Good Luck!
mattillac
redshift
Uhh.... everyone is behind you..
RUN!
M
riverman
QUOTE (scott thacher @ Feb 22 2005, 09:18 PM)
Whenever I go to work on the car or go golfing, I always tell my fiance, "Whatever time I say I'm going to be done - add on an hour." With that list, there's a lot of things that won't go as smoothly as you think. Good luck!
SteveSr
QUOTE (riverman @ Feb 23 2005, 06:26 AM)
[ "Whatever time I say I'm going to be done - add on an hour." With that list, there's a lot of things that won't go as smoothly as you think. Good luck!
agree.gif better add on about 50% Scott.........Good luck anyway beerchug.gif
SteveSr
Hi_Fi_Guy
Good luck!
