Thanks for all the interest
We're planning to give up the shop, move to AZ and I don't relish the thought of transporting all the vehicles, so I'm thinking about letting a few of them go.
First up, the infamous 'BB': (UPDATED 6/11 to add a few forgotten items)
* Fresh Type-4-Unleashed (Richard) 2056cc Motor - galley plugs drilled and threaded, new crank, reconditioned rods, bearings, 96mm KBs, Mahle jugs, Raby 9580 cam, new lifters
* New modified T-1 oil pump, new 7mm valve guides, new s/s valves, new Chromoly push rods & 911 swivels, 9:1 C/R, entire rotating assembly balanced
* Italian Weber 40IDFs w/ velocity stacks, Rotary'14 s/s fuel lines, CB/K&N Air filters, CSP throttle linkage, Pertronix ignition, Bosch Blue coil, EMPI breather box
* SSI stainless steel heat exchangers, new Porsche 'Banana' muffler, 140 lb rear springs
* THOMAS-built side-shift transaxle, 911 sport mounts, new Sachs 6-puck clutch & T/O bearing, good CVs, bronze shift rod bushings (F&R), Tangering Racing spherical firewall shift bushing
* New PMB ATE Calipers, ATE 19mm M/C, good rotors & pads, (also comes with 4 brand new Zimmerman rotors in boxes), Bruce Stone rebuilt pedal assembly
* * Less than 4k miles on drive train and braking system
* Pretty much a rust-free car, hell hole has been repaired, new battery tray installed
* Floor boards, firewall, longs and jack posts are all great, fiberglass rockers
* Back-dated ('71) bumpers, very nice chrome with good rubber bumper-tops
* Euro turn signals F & R, Pilot fog lights hidden behind the horn grilles
* New Odyssey 925 battery, new ignition switch, good starter & alternator
* Paint is OK, not great, comes with freshly-painted black front hood
* Smooth black targa-top, also comes with a tan-colored 'summer' top
* Tan interior, leather seats, tan carpets & dash-pad
* ATS Classics with new 195/65-15 Kumho tires
* Formuling Steering wheel (Nice stock wheel included), Italian Air Horns
* Alpine AM/FM/CD stereo w/ Pioneer 6" in door panels & Blaupunkt 6" speaker pods
* * A/C, condenser hole in front trunk currently covered with CKF sheeting
. . (comes with a replacement front trunk floor panel and tan carpet floor board)
* * Also comes with parts to rebuild the front suspension.
This is about all I can think of at the moment. Feel free to ask any questions in case I missed something.
Current pix
Back end - when it still had the Triad duals
Interior - worn in places, but comfy - (lower dash pad has since been installed)
Under carriage - solid
Drive train - see list above
With the summer-top (matches the interior) & old set of ATS wheels (circa - early 2012)
