QUOTE('73-914kid @ Jun 16 2015, 04:05 AM)
So, perusing around the car I'm restoring at work... not gonna say which, but it ends with a 7, I found this old unused sticker underneath one of the floors. It appears to be a driver registration sticker from back in the early 70's.
It asks for driver name, blood type, most recent tetanus shot, and something else that is obscured with dirt (I'm afraid to clean it) in both German, and English.
Does anyone have any idea what this sticker was used for back then? This thing definitely pre-dates me by a couple (many) years. My best guess is that it was given to a driver to put on his helmet as he went through tech inspection, like they did in the SCCA back in the 80's.
Ethan,
I think you can clean the dirt carefully at both that bottom line Y at the top & bottom of the green circle where it probably tells organization & track where it was to be used.
Do everything gently & start with a dry Q-tip to try to brush away anything loose. Depending upon the sticker's paper material, you'd use different stuff to clean it. I'd suggest asking someone at Cal Poly Spomoni's main library archives, cuz they'll know more about restoration & preservation of paper dox.
It looks like a German track name where the "S.....erne" ?? shows thru at the bottom, but I don't know them all - nor even many - even though I was a HS senior & college age kid (about your age now) then when they ran those XX7's in the `69-75-ish era (don't recall exactly when they completely stopped running them in Germany & then only in the USA in CanAm etc. thereafter). It doesn't look like "Circuit de la Sarthe" for Le Mans to me.
Since it looks to be blank & unused, so my guess is that it blew away & under where you found it at that track, so they probably gave the driver another for that race at track "X".
It was issued at that driver for their EMTs in the case of a crash.
Thanx again for coming out to our Concours, as a lot folks told me during the day that it was cool to see your 914 in person & some to have met you, aftr reading the article. Also - congratz on your internship at PMSNA (PMNA?), as I didn't realize you got that!
Not much help I know, but maybe Sir Andy &/or some of our German members on here will recognize the track &/or racing org. from the visible few letters in the green ring?
PS - P-car Trivia Pop Quiz: Did anyone there tell you what the plastic bin behind the engine over the rear of the transaxle was for?? Rick Perkins of PCNA told me when he came out to check out my `73 for the HO & BO Recalls & showed me a pic of Leno's or Seinfeld's of this car you're restoring (having a half-zymer's moment, I think S's), & I didn't know until he told me back then either.
Others - please give Ethan a chance if you know, before you pop in with an answer on here!
Cheers!
Tom
