QUOTE(toolguy @ Jun 20 2015, 03:26 PM)
.03mm is .0012 inch. . it might fit if you freeze the bushing first. . .
If it were me, press fit interference for something around 15mm [9/16] would be .0005 thousands inch. FWIW, If you don't freeze it to shrink it, since it is brass / bronze it will probably press in and just shave off the excess and not stay tight after usage.
Drilling a percision hole without an accurate mill will be a shot in the dark. . you're playing with thousandths of an inch. . A hand drill or a cheap drill press wont cut it. . I generally drill the hole close to the diameter and ream it to the correct diameter with percision reamers. . Another way to do it is once the bushing is in place, center punch the steel hood bracket all around the bushing to expand the steel.
A twist drill can drill a hole larger than the diameter as the drill want to untwist under load. You may want to try it on a test piece first. I am sure I have extra hood hinges if you need them.
Bruce
