QUOTE(Dave_Darling @ Jun 21 2015, 11:55 AM)
Judging from the photo, you don't have much if any ground path for that starter. It grounds through the body of the starter, through the trans, then the trans ground strap, then the chassis, the battery ground strap, and to the battery (-) terminal.
In the photo, the starter isn't even connected to the transmission, which means no ground path.
--DD
Thanks for everyones input. Dave, I did figure that out and hooked a set of jumper cables to the starter then to the trany strap and it would kick out but wouldn't turn.
But I did finally figure out the problem. What I didn't show was a cut off switch I installed that broke the connection of the positive cable to the starter. The switch must be not 100% effective because it would allow some of the current thru, enough to get a click. Dummy me forgot to switch it to full flow, now it works. I put the old starter back on.
On a side note I did find by Slits comment that the starter is the wrong one. Anyone have the right part number for the correct starter at Autozone? ....of course I've long lost the receipt but would be good for future reference.
Dave
