Hi all, I purchased a set of turbo tie rods , to replace The old and tired knuckled tie rods on my 1973 2.0 Connected into steering rack beautifully with washers. The problem I have is on both ends the castle nut won't go down enough so the cotter pin could fit through
I now have to stripped nuts. haha on both side as I could not tighten the bolt down enough to draw the shaft of the tie rod ends up.
Make me wonder if I have the right tie rods.
I even used my car jack to try and lift up the triode into the shock housing. All I did was lift my car.
I made the little hat out of fun and frustration
Maybe I have the wrong tie rods or tie rods ends. When I purchased it said compatible for 1.7,1.8,2.0. However on the packaging when it arrived it said compatible for 1.7. I went ahead with the install attempt but now I am stuck.
Solutions? New tie rods, or tie rods ends? Etc.
Thanks,
Gary Click to view attachment
