Full Version: Removing a VIN sticker
jim_hoyland
Thanks to Socalandy; I have a replacement VIN sticker for the driver side door jamb. The original sticker got mangled and needs to be replaced; it's stuck on the metal pretty good. What's the best way to loosen the adhesive so the sticker can be peeled back and removed ?
Mike Bellis
Hair dryer or heat gun. Don't get it too hot!
jim_hoyland
QUOTE(Mike Bellis @ Jun 22 2015, 06:54 PM) *
What's too hot ? Warm to the touch ?
Mike Bellis
When the paint bubbles, that's too hot.
You want it warm but not to hot to touch. A finger nail or plastic scraper will help too.
toolguy
Use a Popsicle stick or better yet a doctors tongue depressor. . sharpen the end
so it is sharp, like a chisel blade. . use this to ease off the old sticker as it won't hurt the paint. . It's a go slow project, and a hair dryer will give you the right amount of heat without overheating the paint. .
jim_hoyland
Thanks.
EdwardBlume
I've found goo be gone to work well in certain applications of the sticky kind...
MJHanna
Don't laugh but they make plastic razer blades. They work well taking off , clear bra's and other stuff on paint with out damging the paint. Use with the heat and
alcohol.
jim_hoyland
Update: Used the heat gun with a popcycle stick that was filed to look like a chisel. Took all of 5 minutes to remove the sticker. Then I used Terpentine to remove the remaining adhesive. Worked out great smile.gif
And under the old VIN was the original color of the car......
