porsche-tom
Jun 25 2015, 06:47 PM
Hey guys,
So im sure some of us have some random questions (914 related) floatin around in our heads through out the day that are not quite thread starting questions. So if you have a random or stupid question im sure someone else has wondered it. Here ill start
Click to view attachment What is this center console? i know its aftermarket is it at all valuable?
Click to view attachment What exactly are these?
Click to view attachment I see alot of v8 and performance swap cars have the tubs
cut out, is this just for more air flow? or cooling?
Harpo
Jun 25 2015, 06:52 PM
1) AMMCO?
2)In modern day cars they are drains so the ecoat can drain out of the cars after they are immersed in ecoat. Because we don't have ecoat something else had to drain out?
3) air has to escape somewhere to have max cooling effectiveness.
dudzy's914
Jun 25 2015, 06:56 PM
I HAVE A STUPID QUESTION!
What kind of battery is supposed to fit to the back of the back pad light?
76-914
Jun 25 2015, 07:48 PM
#2- factory holes for welding access.
No battery. the lamp goes there. it's cylindrical.
Mike Bellis
Jun 25 2015, 08:17 PM
QUOTE(dudzy's914 @ Jun 25 2015, 05:56 PM)
CR137
abes914
Jun 25 2015, 08:46 PM
"...cars have the tubs cut out"
will this make my car faster?
catsltd
Jun 25 2015, 08:50 PM
I picked the car up yesterday.74-914.
Took it to my brother who is a VW nut and asked him where do you check for coolant.
Glad I did not have to ask here LOL.
r_towle
Jun 25 2015, 10:20 PM
Where is my engine?
falcor75
Jun 26 2015, 02:25 AM
Can you put a turbo on a 914?
dudzy's914
Jun 26 2015, 06:16 AM
I'm glad I found this thread...
Can I use steelie lug bolts for 2.0l alloys?
914Sixer
Jun 26 2015, 06:45 AM
NO you must use the correct bolts, steel wheel bolts are to short for alloy wheels, they only go in a couple of turns.
EdwardBlume
Jun 26 2015, 06:48 AM
Is that a real Porsche?
mbseto
Jun 26 2015, 06:59 AM
QUOTE(abes914 @ Jun 25 2015, 10:46 PM)
Yes, in the sense that an overheated engine will slow the car down.
If you see the tub cut out like that, you should also see a radiator in the front.
sb914
Jun 26 2015, 08:04 AM
Do these cars rust ?
Bob L.
Jun 26 2015, 10:15 AM
QUOTE(Harpo @ Jun 25 2015, 07:52 PM)
1) AMMCO?
RE #2: Those plugs are all around the 914. One theory which make sense to me is that the spot welders use those holes to access parts of the chassis for welding. Then they were filled with those plugs and seem-sealed.
Bob L.
Jun 26 2015, 10:35 AM
Now, My own stupid ?.
I have been thinking through the Subaru conversion process. I would like to engineer as complete a unit as I can which would contain/hold the engine, ECU, exhaust and, yes, even radiator(s). As close to plug and play as possible.
Having read lots about the poor airflow around the back of the car for cooling, I understand why everyone has gone with the front mount rad. I have also read about some folks who have ducted air through the front bumper to the front brakes for cooling.
Do you see where I'm going here?
Here comes the stupid part...
Could enough air be ducted from the bumper, through the frunk, into the longs and back to the engine bay and through the rad(s).
There would be an electric fan as well, pulling air from the tail end.
I'm sure some air would get through. But enough??
Brian Mifsud
Jun 26 2015, 10:39 AM
That's your backup startup battery. 12 volt Lithium Ion AAA
brant
Jun 26 2015, 10:41 AM
QUOTE(Bob L. @ Jun 26 2015, 10:35 AM)
no
Jonathan Livesay
Jun 26 2015, 11:14 AM
We have only one stupid question thread?
thieuster
Jun 26 2015, 11:21 AM
(European specs) "I've never seen a VW like this before. What type is it?"
(In general): "Can you still get spare parts for these cars?"
(Close to insult): "Do you really like the shape of this? It doesn't look like a real Porsche, does it!?"
Menno
SLITS
Jun 26 2015, 01:49 PM
"Wow .... Is that a Classic?"
"Yeh ... and so am I!"
