john914somers
Jun 26 2015, 10:32 PM
Hi I was wondering if you guys think/know if Fuchs are too old and dangerous to race on? Thanks for your input!
brant
Jun 26 2015, 11:07 PM
Been doing so for a long time. Inspect them for rumored occasional cracking. But I haven't found a bad one yet.
They Always pass the annual inspection by tech.
Thousands of them are raced in vintage still, nation wide.
campbellcj
Jun 26 2015, 11:21 PM
I have had and used numerous old Fuchs with no problems as well. I buy good ones, take care of them, and check them regularly as Brant says. I always keep 2-3 sets of wheels around so there are spares.
stownsen914
Jun 28 2015, 06:25 AM
Like any other wheel used for racing, they should be inspected regularly for cracks (I check my wheels after every event), but I'd use them.
john914somers
Jun 28 2015, 10:34 AM
Does anybody think that if you are pushing 300-350hp thru the Fuchs that makes any difference?
Kaeferfreund
Jun 28 2015, 02:41 PM
I think you better should discuss in the direction what kind of Fuchs alloys you are going to use. An old one (eg a "deep six") or a newer version with "H2"? You have to use tubes for the old ones!
stownsen914
Jun 30 2015, 11:10 AM
QUOTE(john914somers @ Jun 28 2015, 12:34 PM)
I would think it's more about side loading than horsepower. Personally I would not worry about 300+ hp on good Fuchs wheels.
brant
Jul 1 2015, 12:25 AM
I agree that side loading would seem much more significant than hp.
Really good slicks generate a lot of grip and should apply much more force
Hp seems even less significant than excessive weight. Like trailers which can exceed their load rates
ThePaintedMan
Jul 1 2015, 06:43 AM
...Which is also a good reason to check hubs too every once in awhile. I know of at least two people who have warped hubs from side-loads produced by slicks (and probably hitting stuff
madmax914
Jul 1 2015, 12:05 PM
I've heard rumors regarding chromed Fuchs, something during the chroming process may compromise the allow.
Larmo63
Jul 1 2015, 11:22 PM
carr914
Jul 2 2015, 04:51 AM
QUOTE(madmax914 @ Jul 1 2015, 02:05 PM)
Don't know enough about Chromeing, but improperly PowderCoating wheels can lead to premature failure. When you PowderCoat wheels, you need to use a low tempature powder & they will "cook" at a much lower temp. High Temps can alter the Alloy
stownsen914
Jul 2 2015, 08:30 AM
QUOTE(Larmo63 @ Jul 2 2015, 01:22 AM)
Yup - the Fuchs do fatigue and can fail. People used to think those wheels were indestructible. They need to be checked regularly like any other wheel used for racing.
john914somers
Jul 2 2015, 10:12 AM
QUOTE(brant @ Jun 30 2015, 11:25 PM)
I do also agree that the HP would be less of an issue than side load but with increased HP you will have a heavier engine/suspension/braking/cooling and of course wider wheels to accommodate the increase in HP/weight/lateral G-forces. Initially I was thinking that I would use 15x8 up front and 15x10 or 12 in the rear. A good source told me that I would probably want 15x10 in front and 15x12 in the rear. I don't want to invest a bunch of money widening Fuchs if they are going to fail quickly and more importantly the danger element. I think I should probably just buy some custom rims.
campbellcj
Jul 2 2015, 06:53 PM
I've dodged the issue by using new Braid and Fuchs wheels - better piece of mind now that my car goes, turns and stops a heckuva lot faster than before (10" slicks and ~240whp)
brant
Jul 2 2015, 07:50 PM
QUOTE(campbellcj @ Jul 2 2015, 06:53 PM)
Chris. Are you on 17's?
Your going to need to switch to 15's when you eventually go W2W.... And the day is getting close now.
campbellcj
Jul 3 2015, 06:50 PM
QUOTE(brant @ Jul 2 2015, 06:50 PM)
Nope! Actually I went back down to 15's (8 & 9) from 16's. Better clearance and lower weight. And I am still planning to get race licensed as soon as I can do the required classes - life keeps fuching up my plans though.
brant
Jul 3 2015, 11:43 PM
QUOTE(campbellcj @ Jul 3 2015, 06:50 PM)
It won't be long now....
The car is beautiful. You will get in wherever you want.
FIA classes will be really faster than you might want with that giant motor. Ever think about a 81x66?
GaroldShaffer
Jul 6 2015, 06:48 PM
Fuchs can crack for sure. This one was on a parts car I picked last fall. As you can see the rims had zero curb rash. Rim wasn't bent either. I always check my fuchs before any Autocross or track day.
