last337
Jun 27 2015, 02:12 PM
Almost have this thing running. Got the wiring all sorted for the most part today although I think this battery may have crapped out. I do have a question about the distributor wire coming off. It has a black wire on it going to condenser then coming off again. Does that go to (-) post on coil or (+)? All I see is reference to a green wire but all I have is black. I do remember changing the condenser at some point so is that why it is black now? I do see a green wire in engine compartment that was grounded behind battery and clipped at some point. Could that have been it? Should that wire go to ground instead of (-) on coil?
zambezi
Jun 27 2015, 02:47 PM
negative side of coil goes to distributor and tach. positive side goes to ignition switch.
