Ansbacher
Jun 29 2015, 11:32 AM
What is the latest proper fitting Optima Battery for a '74 2.0L ?? I am especially concerned about height restrictions, as my current conventional battery JUST clears the rain tray.
Ansbacher
sportlicherFahrer
Jun 29 2015, 12:32 PM
Should be a group 42 IIRC. If you're going the optima route and are looking for a good solid way to mount it, Triad makes a killer mount plate for a good price. Not really any good pics on the site, but its a plate that bolts to the bottom of the battery using stainless hardware(included with the plate) in 4 spots. Then your regular battery hold-down bolt bolts the plate to the car's tray.
Triad West Performance
GeorgeRud
Jun 29 2015, 12:50 PM
I had a 43R in mine as the terminals were in the correct orientation for the car, but had to slice off the bottom mounting tabs on the sides to get it to fit correctly on the battery tray. Then I fabricated a wider battery mount to hold it down properly.
Check posts about Optima batteries - it seems that their quality has gone downhill. I had to replace one after just a few years, so now I stick with the easy to source Interstate bartteries and just keep the battery area clean, use dielectric grease on the fittings, and use a battery hat underneath to neutralize ant spilt battery acid.
Johny Blackstain
Jun 29 2015, 02:39 PM
I refuse to put a lead/acid battery in my LE ever again. The yellow Porsche acid pad that fits under the battery does not do a damned bit of good as far as I'm concerned. Optima 34R with the bottom tabs/ears sliced off the sides fits my 74 2.0 perfectly. I agree that Optima quality has gone downhill lately, however it's still cheaper than repairing rust caused by acid spill, acid boilover or rain/wash water mixed with battery acid.
saigon71
Jun 29 2015, 02:42 PM
I went with the Optima 34 (not R). It puts the posts on the outboard side so they don't interfere with the stock rain tray. The rain tray hit the posts with the 34R.
It came with everything needed to mount in the stock location and fits well.
I can't speak to the downturn in quality of these things...as this is my first one.
Ansbacher
Jun 29 2015, 07:40 PM
Responses very helpful and really appreciate the pics.l.
Ansbacher
Big Len
Jun 29 2015, 08:29 PM
QUOTE(saigon71 @ Jun 29 2015, 04:42 PM)
Click to view attachmentHave exactly the same setup.
somd914
Jun 30 2015, 03:41 AM
Do yourself a favor and search the World for Optima issues and also Google it.
I'd either go for a Westco Miata battery or an Odyssey PC925. Plenty of mounting options and not difficult to fabricate your own.
