74 1.8 L-Jet
Has any one ever had a fuel pressure regulator get stuck from sitting dry?
My car has been on jack stands for 4 years. and I finally got all the fuel lines back in.
No fuel was going to the fuel rails. I tested the pump and its pumping just fine but no fuel seems to get past the pressure regulator. I took it apart and soaked it in gas and bench tested it with the pump and it seems to be flowing good now. I also checked the cold start valve, fuel rails, and they are not blocked.
Have to put it all back in and see.
Seems like it just got stuck and would not allow fuel flow. Possible?
