I have it but it won't attach to this reply. PM me with your email and I'll send as an attachment. I also have the ratios on a table which shows which gears for stock 4 and 6 901, 2,3 & 5 are different.
john rogers
Feb 24 2005, 10:22 PM
Download my GEARS.EXE from the Bird board and install it. You can even printout the results into a text file.
ClayPerrine
Feb 24 2005, 10:38 PM
Here is the factory gear chart for 901 transmissions. I posted this earlier. It has top speeds for each gear too.
Trekkor
Feb 24 2005, 10:47 PM
Thanks Clay. What is the stock '74 gear set?
KT
xitspd
Feb 24 2005, 10:51 PM
901 chart attached.
ClayPerrine
Feb 24 2005, 10:56 PM
QUOTE (trekkor @ Feb 24 2005, 10:47 PM)
KT
The factory gears for a 74 914/4 are:
First A Second F Third N Fourth V Fifth ZD
Factory Six transmission gears are:
First A Second GA Third O Fourth V Fifth ZA
My transmission (close ratio 4 speed with a long over drive fifth):
First A Second F Third ZD Flipped Fourth S Fifth HB Flipped.
Flipping the gears reverses the ratio that the chart shows.
