Full Version: Transmission mount torque settings and other questions
john77
About to go in and swap out my mounts. Can anyone tell me the torque settings for the transmission mounts? I can't seem to find them, or anything about the transmission mounts, in my Haynes manual.
Thanks
John
Mueller
Usually you can just use the chart in the 1st chapter I think, it is based on bolt size.
Most of the values if you google that bolt size should within an acceptable range also.
john77
QUOTE(Mueller @ Jul 4 2015, 10:13 AM) *
Ahhhh, thanks. That's great to know.
john77
Okay, so now I'm under here I have a couple more questions, before I screw something up smile.gif
How far do I drop the tranny?
By the look of the bolts that go through the centre of the mounts and into the tranny about 2-3 inches to clear the end of those bolts so I can then slide the mounts down and off, right?
john77
QUOTE(john77 @ Jul 4 2015, 10:42 AM) *
Okay, so now I've got all the nuts undone I realize how stupid this question is. Nothing to see here folks, carry on enjoying your 4th!!! biggrin.gif
